Old 06-14-2011, 10:44 PM
dasr12006 dasr12006 is offline
Vehicle: 2007 Ram
dasr12006 is on a distinguished road
Default tail lights not working
Searched but didnt find anything, I will continue searching on here incase I missed something.
Ok, so heres the story.... I bought a 2002 Ram 1500 with 4.7L motor from a buddy, he actually kinda dumped it on me. I said I would like it but was not ready to buy it and he just dumped it at my shop. It has sat for 3 years. Just got it on the road and like any vehicle that sits, its got little issues popping up. Tail lights are not working. Checked all fuses, put a test light to the relay socket and that appears to be working. My mechanic friend was reading the wiring diagram and we tested to the best of our understanding and right now its pointing at the gauge cluster or the body control module? which both receive signals from the headlight switch. Another thing I found odd was fuse #17? was not plugged in. I swapped it with #7? which is power seats, this truck does not have power seats. Not sure why that was like that but still did not correct the issue. Installing that fuse did put power to the relay that controls the lights.
What am I missing?
Find a powder coater!
http://www.powdercoatingboard.com/coaters
Old 06-14-2011, 11:23 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Is it all the tail lights (Brake, Signal and Park lights)? and both sides?
If you have the legend for the fuses, trust/use that. There are a few differences that don't always make it to the service manual, and may be in an addendum I don't have.....but based on the wiring diagram I have -
Fuse 17 (15A) should be the fuel pump.
Fuse 15 (50A) should power the park lights through a relay.
Fuse 7 (50A) is for the power seats....whether or not they exist.
The turn signals/brake lights are directly connected to the FCM (Front Control Module), which under the front of the IPM (AKA Fuse Box).
brad
Interested in one of my mods?
Old 06-15-2011, 09:45 AM
Vehicle: 2007 Ram
all the lights work except the tail/park lights. turn signals, brake, flashers, reverse, cargo light.... they all work. Could it be the relay?
Old 06-15-2011, 09:54 AM
brad12kx's Avatar
Rep:2581
I could be the relay....
The relay position is marked inside the lid of the IPM cover. Listen to it while you have someone turn the lights on and off. You should hear it click. If it clicks, it's probably OK. The relay can be swapped with another one that looks the same for testing purposes.
brad
Old 06-15-2011, 11:22 AM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
Default lights
From what you say it points strongly at a fuse,,,,but if it sat for 3 years as you said that points at a wire chewing squirrel. I would disconnect the battery and start checking for continuity from the relay contacts to the tail light sockets. You did check the bulbs????correct bulbs,,,correct insertion,,,,good bulbs etc.
Old 06-15-2011, 04:16 PM
Vehicle: 2007 Ram
its at the dealer, so far its looking like it could be the TIPM (Totally Integrated Power Module)
instrument cluster and tail lights not working 2001 laramie 1500 B Savage Electrical 8 02-05-2015 02:46 AM
2000 Ram 1500 Tail and Dash lights quit working stevegoetsch Electrical 6 02-28-2011 09:10 PM
2000 Ram 1500 Tail and Dash lights quit working stevegoetsch Electrical 1 02-21-2011 06:08 PM
'02 Tail lights and licence plate not working quartercopper Newbie Checkin! 9 10-01-2010 12:21 AM
HELP GUYS conversion 08 to 05 tail lights Steven Custom Dodge Ram Interior and Exterior Lighting 0 01-20-2010 07:06 PM
