Old 06-14-2011, 06:50 AM
jtownes14 jtownes14 is offline
Vehicle: 2004 Dodge Ram 3500 Crew Cab
jtownes14 is on a distinguished road
Angry Help! Bolt won't come out of A Pillar!
Hey all. I need some help. My 04 Ram 3500 has an issue (well really I do) with the A Pillar bolt. I bought a 3 pod gauge pillar gauge cluster to replace the stock grab handle that was loose. I grabbed the 11 mm socket and all the bolt does is turn. I cut the plastic off to see what the issue was and... The bolt has a collar that is pressed into the A Pillar. This "collar" spins when I try to unbolt the a pillar. WTH? If ANYONE has a idea (short of cutting out the A Pillar) PLEASE send it to me!
jtownes14@gmail.com
Thanks!
J
Old 06-14-2011, 02:56 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Can you post a pic? That might help.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-14-2011, 08:19 PM
Sorry but I can not. Took the truck to a local body shop and they loosened up the rib nut (that is what the guy from Dodge told me it was) with a hammer and then cut the bolt and pushed it into the A Pillar. Dodge sells the part, but has no idea how to get the dumb thing out. I used a plastic grommet to hold it in place. There is no issue cause there is no weight involved like when you use the grab handle. So all fixed. Thanks!
Old 06-15-2011, 10:58 AM
Wildcat's Avatar
Rep:166
Glad you got it fixed. Hopefully the body shop didn't charge you too much to do that.
Old 06-15-2011, 02:51 PM
Dang....that sucks that they pushed it through. Did you get it out?
I was thinking there should be a way to grab hold of the ring nut...
dodge ram 5.9, interior, ram 3500
bolt pattern question need help???? slamtime155 2011 Dodge Ram Forum 4 10-14-2012 04:08 PM
Bottom shock bolt!!!!!!!!!!! ggrif Suspension 4 11-05-2010 12:00 AM
New member, V10 broken rocker arm bolt jwright Newbie Checkin! 13 10-07-2010 01:40 AM
2nd gen bolt pattern? BiGDawG Dodge Ram Wheels And Tires 2 09-06-2010 01:21 AM
rim bolt pattern question live2ride Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 08-24-2010 09:36 AM
