Old 05-08-2011, 03:05 PM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Exclamation XTRA POWER MOD moved IAC sensor from Manifold to Intake tube
Hey everyone I've been reading some post that recommend moving your IAC sensor from the intake manifold to the intake tube. The IAC sensor works by sending info to your pcm which adjusts the fuel/air mix, by relocating the sensor from the hot intake manifold (warmer air) to your intake tube (cooler air entering from outside) the IAC would read the temp. of the cooler air causing the PCM to adjust the F/A mix accordinly giving you a bit more power off the line.
Yesterday, while in homedepot buying parts for my home grown ram air mod. I passed by the plumbing section and bought a 1/4" pipe plug. When I reached the parking lot I couldnt wait to get home so I popped the hood, disconnected the IAC sensor, unscrewed the IAC sensor from the intake manifold, bolted in the 1/4 " plug where the IAC sensor was, cleaned the IAC sensor, using a universal bit I drilled a hole on the side of my air filter box (above the filter) to srew in the IAC sensor man did it screw in nice and tight. I doubled checked the sensor passed thru the filter box undamaged and clean. I made sure the side of the sensor that reads was fully exposed so it could properly read the temp. I then snapped in the filter box cover, connected the IAC sensor and reset the computer. As you can see I didnt extend the wires they reached without strecthing to much...Iill be extending them when I get home where I left the wire and electrical tape
Im not sure if I put it to close to the filter but Im thinking the further away from heat the better right???
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 05-08-2011, 04:02 PM
Yep...it would be better to keep it away from the heat if at all possible.
What this does is improve your throttle response, making the truck more responsive to pedal inputs and feel more powerful.
I've done this to several vehicles. If ya pick the right spot it works very well.
Old 05-08-2011, 05:39 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
That's definately a tried, tested, and true mod. Good job, but your avatar confused me, I thought you had a 14x3 air hat set-up? Hahaha.
Old 05-08-2011, 11:34 PM
RAMING IT's Avatar
Rep:65
Default Avatar
Good observation TODDROD! Thats an old avatar pic. I had installed it a few weeks ago after following the 14x3 thread but felt a slight drop in mpg's, a slight gain in performance and a tremendous gain in "vaccum" db's haha.. I just wasent feeling it. But it looks so damn cool.. so I made an executive decision and kept the avatar.
Old 05-08-2011, 11:46 PM
RAMING IT's Avatar
Rep:65
Post Positioning
Ima pick your brain a bit Micheal if you dont mind. Since you've done this mod several times, where would you of put this sensor on a 5.9? Also, would it be illadvised to place it before the filter... for example a ram air tube? I would think the readings would be outrageously colder and do more damage than good. Im ready to be schooled
Old 05-09-2011, 08:37 PM
toddrod's Avatar
Color: Yellow
Rep:55
Really, a slight drop in mpg's? I'm changing my short air intake to a 14x3. I guess I'll find out for myself. Where do you think would be the best place for me to relocate the iac with a 14x3 air filter? Any ideas?
Old 05-09-2011, 10:05 PM
RAMING IT's Avatar
Rep:65
That was my experience with it but honestly I didnt leave it in that long at all and when I did use it i was driving mostly on an incline so i would of probably lost mpg's regardless. IAC i wouldnt know were to place it Im guessing on the bottom plate were the filter sits would be a good idea i think.
diy, iac, intake, manifold, sensor
3.9/5.2/5.9 Intake Removal & Installation RamTech Dodge Ram Knowledge Base 6 08-28-2013 06:03 PM
oem intake tube swap autobred Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 36 05-02-2012 12:15 AM
Blown Head Gasket? or Intake manifold? gvangerven 4.7L PowerTech V8 Specific Topics 22 02-06-2012 09:30 PM
Intake manifold soco native Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 13 02-06-2010 08:52 PM
What exhaust - Intake - Power Chip Do I Get? naicam29 Newbie Checkin! 10 11-25-2009 07:06 PM
