Old 04-29-2011, 04:15 PM
jimhs
Default Climate Control Panel Lighting
I have a 2004 Dodge 2500 4X4, 5.9 Cummins, crew cab, six speed manual transmission. Can anyone tell me how to get to the bulbs that light up the control knobs? Mine are evidently burnt out and I have to turn on the dome lights to adjust the heater controls when it's night time. Thanks, I appreciate any help.
Jim
Old 04-29-2011, 07:09 PM
Jim,
Welcome to the forum! What part of Eastern Oregon are you in?
As far as those bulbs, you need to pull the center bezel off the dash, unplug the wiring harness to the backside of the controls, then unscrew the control module from the bezel.
I think you'll find that the bulbs are integrated into the circuit board and are not separate from the controls. If that is the case, and it is on mine, you'd have to replace the control module to get new lights to work.
Old 04-29-2011, 11:36 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
On my 02, on the back of that panel, the bulbs were a screw-in type and weren't hard wired to the circuit board. There were like 3 or 4 little lights.
Old 04-30-2011, 10:17 AM
jimhs
Thanks for the help you guy's. I guess that panel just "Pops" out?? I'll take a closer look and see if I can figure out how it comes out of there. Thanks again for the help.
MADDOG, I'm in Baker City.
Jim
Old 04-30-2011, 04:55 PM
jcasey10's Avatar
Rep:869
The front panel will just pop off and then the controls are screwed in to the back of the panel
Old 04-30-2011, 05:48 PM
Jim...yer lookin' at a LaGrande boy here.
Old 11-06-2013, 09:42 PM
Jimmygunz3 Jimmygunz3 is offline
Vehicle: Dodge ram 1500
Jimmygunz3 is on a distinguished road
I am having the same problem on my 08, there are 3 small lights that unscrew but. I cannot find a replacement, the dealer said I have to buy a new control panel. What did you guys do
Old 11-06-2013, 09:45 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
http://www.ramforumz.com/showthread.php?t=49034 scroll down to the bottom they talk about the HVAC bulbs you can get them from superbright leds
Dual Zone Climate control issue billw Heating & Cooling 3 12-31-2010 09:29 PM
climate control zjp692004 Dodge Ram General Discussion 1 11-10-2010 08:59 AM
lights on climate control panel dim redeye4u Electrical 4 06-18-2010 09:58 AM
Dash removal/ Heater core replacement Trishafer Heating & Cooling 6 02-25-2010 07:23 PM
Climate control GTyankee Dodge Ram General Discussion 0 02-02-2010 06:44 PM
