Old 04-18-2011, 11:51 PM
ronanderson57 ronanderson57 is offline
Vehicle: 2006 Dodge Ram 3500
Color: silver
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
ronanderson57 is on a distinguished road
Default Trailer Brake Light Problem
I have a 2006 Ram 3500 4x4 Cummins. My problem is that when I hook up my 5th wheel trailer or my boat trailer. All the lights work on the trailers except the Lt. Brake Light. The 4 way flashers work, the turn signals work but the Lt brake light does not. Being that the trailer is just a 4 wire circuit for the lights, Lt, Rt, turn signals which also are the brake lights and the running lights and ground. All the truck lights work fine. Someone told me that because Dodge uses a 4 light system in the rear. Meaning separate turn lights and brake lights. That when you hook up a trailer there is a unit that now sends signals to the trailer as to which filament to light up between the brake and turn signal. Does any one know anything about this? I have oredered the Maint Manual CD but it hasn't come yet and I would appreciate any ideas. Thanks Out of ideas in Palm Springs.
Ron
Old 04-19-2011, 01:30 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
What you have been told is not completely accurate. Dodge controls the signals to the trailer independent of the truck itself. The signals all come from the TIPM (Totally Integrated Power Module). Here is the wiring diagram for the trailer tow wiring in your truck.
brad
Interested in one of my mods?
Old 04-19-2011, 02:42 AM
Rep:2616
i have found that some vehicles & trailers may not be mated exactly the same, you may have to change a pin in the pigtail on the trailer
just to do a quick check, have another vehicle plug into the trailer pigtail, it doesn't matter which brand vehicle
Old 04-19-2011, 08:51 PM
Color: silver
Thanks so much for the diagram. I'll check into the wiring now and see if I can find where I'm losing the signal. Also where is this TIPM Located? Is it in the main Fuse Panel? Ron.
Old 04-19-2011, 11:35 PM
brad12kx's Avatar
Rep:2581
The TIPM is the power distribution center with all the fuses on top.
brad
Old 04-20-2011, 04:25 AM
Color: silver
Thanks for the info. Ron
Trailer lighting problem ronanderson57 Newbie Checkin! 13 04-25-2011 02:02 AM
Brake light switch issue bubbakev87 Electrical 3 03-18-2011 10:11 PM
2003 ram 3500 trailer lights problem 2003duallyram Custom Dodge Ram Interior and Exterior Lighting 5 11-27-2010 11:10 AM
In dash brake light Th4m0n3ysh0t Electrical 1 11-13-2010 10:04 AM
4x4 Indacator Light Problem allencoon Electrical 2 10-11-2010 10:30 AM
