Old 04-07-2011, 04:31 PM
Biggmaxx's Avatar
Biggmaxx Biggmaxx is offline
Vehicle: 2011 Dodge Ram 1500 Sport
Biggmaxx is on a distinguished road
Default HID relay buzzing?? Anyone know a remedy
i installed my hids from hidextra, heads and fogs and so far have been nothing but problems. Now my headlights are in and only when the truck is running and the headlights are on the relay is making a loud buzzing sound that is definitley going to be intolerable. Anything from anyones experience that i can troubleshoot??
Debadged, Smoked Tails, HID heads and Fogs, AEM Bruteforce intake, Bakflip G2, Mufflex DOD18M....
Old 04-07-2011, 06:38 PM
Biggmaxx's Avatar
No worries, after some research just went to radio shack and purchased a 470u 35v cap and bridged between pole 85 and 86 in the relay and it worked like a charm, no more buzzing at the cost of $1.49, but with plenty of aggrevation
Old 04-07-2011, 06:50 PM
ughhh...sounds like a lot of work. I was gonna suggest replacing the relay.
Old 04-07-2011, 06:56 PM
Biggmaxx's Avatar
i did replace the relay, i happen to order 2 relays just in case but it wasnt that. apperently with these trucks it send pulses of electricity which long story short make the relay buzz, i dunno, im no genius with stuff like this but as long as it worked im happy, i just hope they hold up now otherwise im ripping it all out and going stock with no headaches
Old 04-07-2011, 06:59 PM
Tell me about it....I have been through 4 sets and 7 different harness arrangements (resistors, caps, relay, trigger wires, etc...) and still have a problem with flicker. For now, my low beams are wired independently of the factory harness with a separate switch. Works good but I want to use that switch for a second set of aux lights.
So, I'll have to find another HID supplier that has figured out the CanBus voltage issues.
Old 04-07-2011, 07:17 PM
Biggmaxx's Avatar
man, you have more patients than i do, 4 sets and 7 harness arrangments, i woulda called it quits a long time ago
Old 04-07-2011, 11:59 PM
wigbill98 wigbill98 is offline
Vehicle: 2009 Dodge Ram
Rep:44
wigbill98 is on a distinguished road
Its not the relay, its the trucks electrical system. Our trucks have a pulse modulated electrical signal. What is happening is the computer is sending out a electrical signal that looks more like a AC sine wave compared to a DC sine wave.
Here is the difference between the 2 waves:
http://www.kpsec.freeuk.com/acdc.htm
What this is doing is causing your relay to turn off and on at a very rapid rate causing a Buzz or chatter. The relay requires a constant 12v and with the pulses the coil in the relay opens and closes.
Only real way to solve this issue is to install the capacitors so they can store extra current and keep a constant 12v going to the relay to keep it closed!
Hope this helps.
-Will
Mods = Retro-Fit Projectors & HID's with painted housing, Welded Muffler, VHT Nite-shades Chrome License Plate Frame...OH YEA!
Old 01-26-2014, 03:08 PM
dauer53's Avatar
dauer53 dauer53 is offline
Vehicle: 2011 1500 Quad Cab Sport 4x4
dauer53 is on a distinguished road
Would it be possible to get pictures of what you're talking about? I'm experiencing the exact same thing right now but I'm less electrically inclined??
Old 01-27-2014, 09:17 AM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
Some people have used these http://www.amazon.com/Anti-flicker-C.../dp/B00BWAH6EK
- here's a video
Old 01-28-2014, 07:21 AM
dauer53's Avatar
I tried the capacitor and now my lights won't turn on... Any ideas?
Hmmmmmm.....HID Relay Buzzing Ramathorne Custom Dodge Ram Interior and Exterior Lighting 29 03-19-2013 11:14 PM
My truck has trouble starting... no one can figure out problem Pork Chop 3.7L PowerTech V6 Specific Topics 15 05-14-2011 10:14 PM
03 flasher relay question southpaw5m Electrical 11 04-24-2011 02:21 PM
Help hid conversion kit wont work on fog lights pacificflip72 Custom Dodge Ram Interior and Exterior Lighting 22 02-09-2011 01:20 PM
98 Ram 5.2 Occasionally Dies While Driving KenS999 5.2L V8 Specific Topics 5 01-11-2011 05:11 AM
