Old 03-26-2011, 09:20 PM
schrubber schrubber is offline
Vehicle: 2011 ram 1500
schrubber is on a distinguished road
Default 2011 Sentry key programming not working
Hello group, having a problem programming a new Sentry key in a 2011 RAM 1500 ST 2X4 with sentry security lock. I purchased a repalcment sentry key with the chip (black key) had it cut and tried to add to the ECM and can't get it to respond.
I used the 2010 procedure to use the 2 original factory keys but I never get the blinking security light when I insert the second key. The owners manual says it has to be done at the dealer. Has anyone been able to add a key on a 2011 or has RAM changed the procedure for the 2011 that you must go to the dealer?
Thanks
Schrubber
Old 03-26-2011, 09:28 PM
Rep:2616
to program a FOB or FOBIK ( frequency operated button integrated key )
if you have 2 working FOBs, you can program a 3rd FOB yourself
if you only have 1 working FOB & want to program a 2nd FOB, it has to be done by a Certified Locksmith or the Dealer, although some auto audio alarm places can do it
Old 03-27-2011, 11:54 PM
Default 2011 RAM Sentry key adding
Still interested if anybody with a 2011 RAM 1500 has been able to add a new sentry key using the owner 2 key method? I have tried several times over the past 2 days and can not get the blinking securty light when the second key is inserted and turned to on?
Old 03-28-2011, 07:47 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
It doesn't work on the 2011s. If you look in the owner's manual where the procedure was for 2010 it says to contact your dealer.
Old 03-28-2011, 08:37 AM
Rep:1845
Keys have to be programmed with the wiTECH.
Homelink programming problem solved! jlcosby 2011 Dodge Ram Forum 15 08-14-2013 08:24 PM
2011 Ram 1500 advice before buying airborne89 2011 Dodge Ram Forum 32 06-25-2011 01:34 PM
2011 Ram new Ipod touch 4g not working roadking2001 Electrical 39 05-01-2011 02:19 PM
2011 Mygig in 2010 Ram RootBeer Custom Dodge Ram Interior Modifications - Custom Audio / Video 8 09-11-2010 12:10 AM
Programming a keyfob? StuartV 2009 Dodge Ram Forum 13 01-26-2010 11:15 AM
