Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
Old 03-19-2011, 06:36 PM
Mavericke's Avatar
Mavericke Mavericke is offline
Vehicle: 1992 Dodge Ram D250/350 Conv.
Trim Level: LE
Color: Two Tone Grey
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
Mavericke is on a distinguished road
Default Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel
Howdy fellas, I'm actually a returning member. I guess my account was inactive too long and went *poof*. I'm pretty sure it was the same screen name though. No worries, though I would like to be able to find those old posts if I could. One in particular being the one I posted on where a member was making custom grill guards for my model. Would love to get in touch with him and order a grill guard. Anyways, my first truck was a 92 D50 4x4 with the 318 Magnum. I had lots of problems with it mostly due to the fact that there was a fire under the hood of the truck and we had to redo everything. We did install a new plenum from Hughes (they're shop is less than an hour from me) and that helped alot. We got'er running pretty good, but I ran into some financial problems and had to sell it. I lost about $1700 invested in that project.
The NEW project is my daily driver! It's the same year... a 92 D250, but it's been converted to be basically a D350. This thing came stock with the long bed 3/4 ton rear end I believe... but now it has the dually 1 ton rear end. It had one previous owner. The man passed awaya couple years ago right before I bought my house and the day I drove out to see my house for the first time... I told myself I would own this truck some day. Didn't ever really expect it to happen, but it was a nice thought. My wife stopped by and asked if it was for sale after getting tired of hearing me talk about it every time we drove by, lol! It was supposed to be a suprise, but she couldn't pull off the finances on her own so she let me in on the secret and we had it in the drive way a week later.
They originaly wanted $5500 for it. It books at around only $3k for loan value so I had a hard time getting it. I was able to talk them down to $4300. Some may think that's a bit expensive... but I didn't buy it for the value of the truck. We had a bond the moment I saw it. The truck is priceless to me. And it also has alot of upgrades that don't add to book value. I'll list those below.
She has 150k miles on her, the owner has a log book of every bit of maintenance ever done to her. It fires up with no troubles instantaneously and it has virtually no rust. The frame is solid. He kept up with the Ziebarting for about 6 years after he bought it and I didn't find any receipts after that point. Most of that is peeling off now or already off. Alot of surface rust that can be easily treated. The driver's side rocker has a quarter sized hole in it and under the cab where it connects to the frame on the driver's side... it's got a pretty severe rust hole a few inches wide. Structurally, she's solid, but that spot needs fixed soon and the rest needs treated before next winter.
The old man removed the original bed from the truck and wrapped in cardboard and it has been setting for the last 17 years in a barn in perfect shape. He bought the second one because it was cheap and came with the fiberglass dually wheel wells and it was a bit beat up - so less risk when modifying. Again, I'll talk about modifications below. So, the bed on it isn't bad. It's deffinitely doable, but I still plan on painting the entire truck later this summer and I will be putting the original bed on because it will be less work to paint it. The old bed had plastic liner in it and is set up for 5th wheel hauling... but I hate plastic bed liners so I removed it first thing. It was already cut up due to some mods. I didn't want to climb under the truck to remove the 5th wheel gear so I literally cut the bed liner out with a sawzaw. It also had the metal running gear for a tannoe cover, but no cover so I yanked all that off as well and installed my chrome tool box.
Now, back to the upgrades this guy did... I'll just list everything and make it easy. The guy was an engineer for BNSF railroad and really knew his stuff. This truck was his baby. He used it to haul antique farm tractors to shows and occasionaly hauled a camper. The camper actually sat in the bed of the truck. His modifcations, though crude, were very very effective. By crude, I mean that they weren't done to be "pretty", just to be funtioning. That's my only issue with the truck. You see, I LOVE modding out my vehicles. In fact, if I bought a 50k Ram off the lot with 10 miles on it - the first thing I'd do is take it home and start ripping crap out of it and installing my own upgrades. It's all bout customization and building a vehicle the way you like it. That's why I buy used. Anyways, this guy had all the mods mostly done that I wanted, but they weren't pretty. I like stuff to look as if it was installed at the factory... this guy just wrapped wires in tape and just let them hang on the dash. Not cool. So I'll be taking care of that asap. Ok, now on to the features and mods!
  • An Air bag rear end with auto leveling system that can also be disabled so that the driver has full control.
  • Hydraulic braking set up for traliers.
  • Electric braking system setup for trailers.
  • Upgraded headlights. Super clear white. You only change the bulb, not the entire housing.
  • A built in and well hidden generator for running power tools or whatever else. Obviously, he used it to power his camper.
  • It has power hookups from the battery on the the rear of the truck to power things like winches and 12v tools. It even has special jumper cables he made that connect here.
  • He modified the original manual seats to power seats. Works great!
  • Installed a second gas tank. The tank is installed where the spare should be. It's well protected and very neatly done. The filler spout is on the same side as the regular gas tank. There is a toggle in the cabin that switches from one tank to the next. You can do this while driving.
  • Since there was no place for the spare tire after the second tank install, he built some custom brackets for the front bumper and extended the bumper a good 12" so that the spare tire would set nicely inside and bolt in safely. It doesn't appear to affect gas mileage either! See the pictures.
  • Cobra CB installed, dual antennas.
  • K&N air filter
  • Power windows
  • 5.9L Cummins Turbo Diesel
  • 1 ton dually rear end
  • 5th wheel setup
  • Super quiet aftermarket exhaust
Now, some of those upgrades will be used - other will not. For instance, the front bumper work is cool - for what it is, but I'd much rather have a nice looking grill guard. I don't have a camper, so if I make a long trip, I'll throw the spare in the back. I'd rather it be in the bed anyways so I don't have to climb under the truck to change the tire out. It still has the factory stereo system in it and factory speakers and only half of them work... I will be replacing that very soon. I'm also working on tinting the windows right now with 5% limo tint. I've only got two windows done so far, lol... it's been a pain in the ass, lol! It's a two tone grey with the red pin stripe. I'll be repainting it this summer. Just shooting the outside and stick with the dark grey already on it, just reshooting it and painting the entire truck one solid color. Not a fan of two-tones or pin striping. Probably going to install some simple running board lights. I have a Lund visor (over the windshield) on the way, installing that soon. Swapping out the exhaust for something with a bit more growl in it. Got my truck nutz on order, lol! And... I think that's pretty much it. OH, going to clean up the underbody again and line the bed with roll-on rhino liner AND going to swap out every bulb on the vehicle (including dash lights) with LEDs. I think that's it. Will probably changeout the running boards at some point with something nicer and more shiney! :P
So that's the truck! Whatcha think!?! Enjoy the pics!
The_Mavericke@hotmail.com
1992 Dodge Ram D250 5.9L Cummins Turbo Diesel, 1 ton Dually
Old 03-19-2011, 08:27 PM
WOW! That truck has a lot of cool enhancements.
Welcome to the forum! [Again]
Old 03-19-2011, 09:00 PM
Wanna sell it ? Sounds like a real nice truck . Glad you joined us and welcome to the Z for Rams from Baltimore . If you could go to the top of the page to the User Cp and complete your profile that would be great . Helps us see what you have when your posting a question or comment . Any of your friends have a Ram ? Tell them about us . We would love to have them . You will find this site is full of a lot of talented people . So if theres any question that you need answered , just shoot away . Talk to ya soon . Tom
Old 03-19-2011, 09:08 PM
Mavericke's Avatar
Trim Level: LE
Thanks guys! Tell ya what I'm looking for is a grill guard... a nice one. When I was here before, there was a guy that was making them by hand for a couple hunred bucks and they looked amazing. I can't seem to find any info though. If you know of whom I'm talking about - please, point the way!
Old 03-19-2011, 09:09 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3944
Hello and welcome!
Good to have you with us, I hope you enjoy the board!
Old 03-19-2011, 10:06 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
A big hello and a warm Carolina welcome back to the best Dodge Ram forum!
Old 03-19-2011, 11:40 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
welcome to the forum!!!
Old 03-19-2011, 11:49 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Hello and welcome to the site!
Old 03-20-2011, 12:22 AM
old hot rod's Avatar
old hot rod old hot rod is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
Welcome back Mavericke,
Great post !!!!
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 03-20-2011, 12:29 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Welcome to the forum,
This forum is full of great looking trucks; packed with great mod ideas and there are loads of knowledgeable and experienced people here.
AND - We all like pix! Thanks for sharing yours.
Enjoy the Z!
brad
Interested in one of my mods?
New member and new to dodge 10 ram 2500 cummins macsbees Newbie Checkin! 13 09-05-2010 01:31 PM
2010 May - Dodge Ram Member Of The Month BlueJet 2010 Dodge Ram - MOTM - Archives 23 06-03-2010 10:46 AM
2010 April - Dodge Ram Member Of The Month BlueJet 2010 Dodge Ram - MOTM - Archives 32 04-13-2010 11:48 PM
2010 January - Dodge Ram Member Of The Month BlueJet 2010 Dodge Ram - MOTM - Archives 28 02-01-2010 12:36 PM
2009 December - Dodge Ram Member Of The Month BlueJet 2009 Dodge Ram - MOTM - Archives 20 01-07-2010 04:35 PM
