Old 03-17-2011, 12:55 AM
dburn dburn is offline
Vehicle: 08 dodge ram 1500 4.7
dburn is on a distinguished road
Default can you put the 08 rams 2500s suspension on a 08 ram 1500
hey you guys i was looking at putting the 2500s suspension on my 08 ram 1500 quad cab and wanted to know if it is possible to do so and if it is how would i go about doing it
Old 03-17-2011, 01:22 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Not really possible. 2500 has a solid front axle with coil springs while the 1500 has an independent front suspension.
It might be possible to add the leafs to the back but I have a feeling the 2500's may not mount in the same spot as the 1500
Adding 2500 suspension is only really going to give you a rougher ride and maybe hold the tongue weight of a trailer a little better. It wouldnt up your tow rating at all.
Old 03-17-2011, 09:51 PM
ScatPak07's Avatar
Rep:970
Ya you would have to replace all the axles and then replace the leafs and front setup. That would definitely b expensive and not really worth it. May I ask why you want to do this?
If you want to make a big lifted rig for show purposes or off road then this would make sense. But really it would be better to sell this truck and go and buy a 2500. There will be a lot of man hours to replace it all and just the cost of the whole suspension.
ScatPak07's Avatar
Rep:970
climbing, lifting, suspension, swap, towing
2003 ram 1500 suspension noise ELMORAY 5.7L (345 cu in) HEMI V8 Specific Topics 3 04-27-2011 07:17 AM
Body lift vs Suspension lift ccga3359 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 2 12-19-2010 09:22 PM
2007 1500 2WD 1500 Sport/want Bilsteins and coil spacers/rear blocks DanoHB Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-21-2010 11:59 PM
Ram 1500/ 2500 '97 mantoska Dodge Ram General Discussion 4 03-16-2009 11:56 PM
1,000 off 2009 Rams 07HEMI 2009 Dodge Ram Forum 4 09-25-2008 05:19 AM
