Old 03-12-2011, 12:33 PM
Amp211 Amp211 is offline
Vehicle: 2006 Dodge Ram 1500 SLT
Color: Blue
Amp211 is on a distinguished road
Default HID high and low
i install my bi-xenon hid yesterday and they work great. but my problem is that when my truck is on low beans the light is on high and when i switch to high the light goes to low. that might not be a problem with some people but i got hids in my fogs too so you know when you go to highs the fogs go out, so can somebody help me figure out how to make it so when i switch to high my lights are high and when im on low my lights are low?
Old 03-12-2011, 05:30 PM
I have never heard of that before. Are you wired up correctly???
Old 03-12-2011, 06:02 PM
Color: Blue
i thinks so. i got two wires form the light connected to the ballast, the third wire form the light to the relay, a resistor on both of the original light plug and one of those connected to the relay, the relay is plug into both ballasts and i got the relay to the positive side of the battery and to ground.
Old 03-12-2011, 06:58 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
hmmmm iv never herd of this before but i would just play around with the wires and connections to see if that could be the problem
Old 03-12-2011, 07:12 PM
Color: Blue
im thinking that they cross my wires on my relay. like when my relay is pluged into the original plug that the relay high wire is connected to my original low wire and the relay low is connected to my orginial high. so do anybody know which is the positive wires on the original plug so i can switch the wires on the relay plug? the wire on the original plus is a white one with a green stripe, a black one, and a white one with a blue stripe
Old 03-20-2011, 09:43 PM
darrius2008 darrius2008 is offline
Vehicle: 2004 dodge ram
Color: white/silver
darrius2008 is on a distinguished road
try switching the plug around by the ballest
Old 03-20-2011, 11:28 PM
Chance05Ram's Avatar
Chance05Ram Chance05Ram is offline
Vehicle: 2005 Dodge ram 1500
Chance05Ram is on a distinguished road
This is not the first time this has happened.
Your connection has three wires, the middle is ground the outer is low beam and high beam.
Switch the outer two wires.
My kit had this problem and others aswell.
Old 10-12-2013, 05:11 PM
Tjcaveman Tjcaveman is offline
Vehicle: 09 dodge ram big horn
Trim Level: big horn
Color: red
Tjcaveman is on a distinguished road
i had same problem all i did was swap wiring around at the head lite plug itself. swap the 2 reds black stays in the middle. reds represent high/low that should work.
Old 10-12-2013, 08:03 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Agree with this, probably just need to swap your wires
