Old 03-07-2011, 12:19 PM
Rep:1845
Default Maintainence Recommendations
I'm frequently asked about fluid change and maintainence intervals for Ram trucks so I decided to write up a schedule based on my personal recommendations based on my experiences and observations. These are the guidelines I use for my own personal truck, so I practice what I'm preaching here. I'll also recommend a couple brands of fluids and filters but by no means should anyone limit themselves to these brands if they find another good product. I use synthetic fluids everywhere in the truck. Under NO circumstances should any reccomendation here exceed the intervals listed in the owners manual.
Engine oil - I change mine every 5k miles along with the filter. I use Mobil 1 5W-30 oil exclusively although there are plenty of good oils on the market.Be sure to use the correct viscosity.
Oil filters - I generally stick by Wix but will use Mobil 1, Purolater, Napa Gold (made by Wix), or K&N if I find a good deal on them. I avoid Fram and generic filters unless I know for sure who makes them.
Greasable joints - One or two shots every oil change unless the boots appear full.
Automatic Transmission fluid - I flush mine every 30k miles. This is a overkill, I know, since the fluid is designed to go 100k miles. I don't recommend going over 60k and if you do a lot of towing or heaving hauling, I recommed every 30k. Since filters rarely clog unless there's a transmission problem, I only change mine every other service. I strongly recommend factory filters for this service.
Manual transmission fluid - Every 30k miles with the specified fluid type.
Transfer case - Every 30k miles with the correct fluid type.
Differentials - Every 30k miles but more frequently if much heavy towing or hauling is done. If you tow/haul a lot with a 4WD but don't use 4WD very often, change the rear fluid around 15k and the front fluid at 30k.
Power steering fluid - Every 30k miles.
Brake fluid - Every 30k or whenever I perform any brake service.
Coolant - regardless of the 5 year 100k mile claim, I will not let mine stay in that long; I've seen too many cooling systems start to look nasty much sooner than that. I change mine every 3 years regardless of mileage.
Air filter - Inspect every oil change. Cleane/change as needed.
Cabin air filters - As needed; generally once a year.
Spark plugs - Every 30k miles with NGK. You can go longer but I'd recommend no more than 40k miles because that's when gap erosion becomes noticable to the naked eye. Be sure to apply dielectric grease to the boots. I also recommend antiseize on the threads.
PCV valve - Inspect each oil change and clean or change as needed.
Fuel system service - Once a year. This includes removing and cleaning the throttle body and IAC if equipped.
Decarbon valves - Once a year with Mopar combustion chamber cleaner.
Fuel system additives - One bottle in the tank bi-monthly.
Fuel filter (gas) - Not serviceable except on older models. Change annually if equipped.
Fuel filter (diesel) - Every other oil change if the truck is primarily used on road. For frequent off road use or in dirty environments such as construction sites, I recommend every oil change.
Tire rotation - I rotate and balance mine every oil change. While balancing may not always be needed, I strongly recommend cross rotation at this interval or whenever abnormal wear is noticed.
Alignments - Whenever I notice any kind of lead or pull not related to a tire condition, if signs of abnormal wear appear, after any suspension/steering work, or when new rubber is put on.
Tire pressure - At least once a month or if any kind of abnormal handling appears. More often in drastically changing weather conditions.
Hinge lubrication - Once a year with Wurth HHS 2000 lubricant. It sprays as a liquid but sets into a grease. It's pricey and hard to find in stores but a superior product for getting in hard to reach places.
Old 03-07-2011, 12:27 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Thankis for posting this Randy!!!!!
Old 03-07-2011, 12:37 PM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
You'r a good man Randy, thank you.
Old 03-07-2011, 12:55 PM
I push the skinny pedal
Rep:3277
I sticky'd it so it's easy to find.
Kurtis
Old 03-07-2011, 12:59 PM
Rep:1845
I was wondering who did that so fast!
Old 03-07-2011, 01:01 PM
Rep:3277
Smart like rock... but quick like bunny
Kurtis
Old 03-07-2011, 01:03 PM
Rep:1845
No argument here. I never saw a post go sticky that fast before!
Old 03-08-2011, 02:09 PM
Butter's Avatar
Butter Butter is offline
Vehicle: 2010 Ram 1500 4x4 RC/SB
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
First off thank you for posting this info, it's always comforting to know what the professionals do to their own trucks!
Tire rotation is one thing I have heard several different things about when it comes to how to go about the rotation. I was originally taught to cross rotate but later was told that it could cause belt problems in the tires..So says the belts form a memory once they have rolled in one direction for a while and reversing them is what can cause the problem....Glad to see I have been doing it right
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 03-08-2011, 02:19 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
Glad to see this posted.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 03-08-2011, 02:28 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Thanks for the post Randy! Very helpful.
Dillon-aka, The Little Kid
Strut Upgrade Recommendations?? RaisedRam07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 02-20-2011 11:49 PM
Recommendations for Plugs? Bellzy Dodge Ram Detailing and General Maintenance Forum 16 04-14-2010 02:51 AM
Projector Headlight recommendations MADVILLUN Custom Dodge Ram Interior and Exterior Lighting 6 01-16-2010 11:24 AM
Recommendations? CAI 08Ram1500 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 19 11-09-2009 08:39 AM
Small lift for 98 ram 1500 Recommendations? HAZZARDJOHN Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 10-19-2009 01:09 AM
