Old 03-05-2011, 05:48 PM
jlcosby jlcosby is offline
Vehicle: 09 Ram Laramie
Rep:21
jlcosby is on a distinguished road
Default Homelink programming problem solved!
Have 2011 Ram Laramie and using Chamberlain rolling code opener. Not sure about the model. It is 3 years old.
Attempted the programming EXACTLY according to the manual from Dodge.
Finally gave up. A week later I went back out there, and succeeded. Here is what I did:
Powered off the door opener.
Dumped the homelink codes in the truck.
Trained #1 with a good working remote.
Powered up the opener, hit the "train/learn" button on the opener, went right to the truck and hit the key I had just programmed, and it worked. Only took a couple seconds.
It has been working properly for 2 weeks now.
Give this a shot guys!
Old 03-05-2011, 07:45 PM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
Yeah, I had to fight this same battle.
The problem with rolling code openers is that until you give your homelink a code to transmit, it won't transmit anything.
So, you hit the learn button on your opener, run to the truck and hit the homelink button, but it doesn't send any signal at all.
Once you sync it with the remote it will send a signal and link up to the opener.
Old 03-05-2011, 08:00 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PX8 Black
Rep:2471
Thumbs up
I had the same problem getting mine to work. Thanks for posting this up for others to use.
Old 03-05-2011, 08:45 PM
Yup those rolling code units can make you scream and holler sometimes.
Old 03-05-2011, 08:49 PM
Chubby Bruiser Chubby Bruiser is offline
Vehicle: 2010 Quad Cab
Color: Blue
Rep:84
Chubby Bruiser will become famous soon enough
Good post. Thanks for posting the info. Reps for that.
Westin Nerf Bars, Mopar Chrome Bug Deflector, Mopar Mud Flaps, Mopar Slush Mats, Chubby Antenna, K&N Drop in Air Filter, Bosch Wiper Blades, Weathertech Vent Visors, Mopar Trailer Brake Controller, Reese Tow Package with Anti Sway Bars, B Pillar Black Tape Removed, Mopar Chrome Gas Door, Mods to come - 14 inch Mufflex, CAI, Headers, Michelin Tires, Chrome Bed Rails.
Old 03-06-2011, 12:31 AM
knsram knsram is offline
Vehicle: 2011 Dodge Ram 3500 Crew Cab
Trim Level: Laramie 4x4, 3.73gr
Color: Deep Pearl Red
Rep:20
knsram is on a distinguished road
Glad to hear I wasn't the only one on this.
knsram
2011 Dodge Ram 3500 Laramie Crew Cab 4WD Dually LB
Old 10-29-2011, 08:19 PM
royw's Avatar
royw royw is offline
Rep:39
royw is on a distinguished road
Most excellent instructions! Worked first time.
I thank you. My blood pressure thanks you. Everyone within earshot thanks you!
Admins, can this be made a sticky?
Old 10-30-2011, 03:14 PM
85buggy's Avatar
85buggy 85buggy is offline
Vehicle: 2011 Dodge Ram 2500
Color: Omaha Orange
85buggy is on a distinguished road
Question Opener !!!
Glad to hear this did mine last weekend thought it would make me crazy . I finally got it to work second try after going in the house for a while wondering why i must be so stupid. My daughter wasn't happy that night I screwed up her opener she couldn't get in , turns out the remote battery went dead.
Old 10-30-2011, 04:33 PM
Rep:2640
I had a 2nd person working the opener, while i was out in the Ram, still took a few times
Old 11-06-2011, 11:21 AM
Mykz2011Ram Mykz2011Ram is offline
Trim Level: Sport Quad Cab 4X4
Color: Mineral Grey Met.
Mykz2011Ram is on a distinguished road
My first post....Thanks for the tips, it worked perfectly!
My Diablo Won't Reinstall Stock Tune - Problem Solved! Big Daddy Diablo Predator Questions & Info! 11 10-06-2011 09:57 PM
Tranny problem solved? (Warning) dirtsurferus Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 08-31-2011 10:56 PM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 04:54 PM
Problem not solved Griebz 2009 Dodge Ram Forum 21 09-16-2010 07:42 PM
Body lift steering extension problem solved JMaxx93 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 05-26-2010 12:08 AM
