Old 12-04-2011, 12:29 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Originally Posted by hueveaj View Post
I have 2011 Longhorn Crew. Wind noise similar to blowing over a half full coke bottle, always the same pitch, especially in cross winds coming from the right side of the truck to left. Can be very annoying at times, still no fix for me, pretty sure it is not antenna, as it appears to originate on the driver's side.
It's not the antenna because I have a shortie and still have the same tone in a cross-head wind.
Old 01-23-2012, 06:36 PM
dodgerboy dodgerboy is offline
Vehicle: 2011 dodge ram 1500
Color: Deep cherry red
dodgerboy is on a distinguished road
Default Wind noise
I have the same truck with the same problem. Sept 2011 dealer called it in to fix wind noise coming from front door seals. They called it 'installed foam liners'. It was nothing more than a wedge about 1.5" long by 1" wide that they jammed and glued into the door seal. I found drivers side wedge stuck to the truck body and couldn't figure out what it was until I checked the pass. door. This wedge doesn't work because it causes a 'void' space where it's installed. I want anyone with this problem from USA and Canada to notify me as I need 'ammo' lots of info when I go after the dealer to prove I'm not the only one. According to 'the Forum' there are many who have this factory defect. It's not just 2011, but many years prior as well. Why should we accept this problem when we paid hard earned money to be told by the dealer to 'turn your radio louder' !!!!! With enough info from owners it could be a Class action lawsuit. Thanks
Old 01-24-2012, 04:51 PM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2014 Dodge Ram 1500 Crew
Color: PX8- Black Clear Coat
Rep:31
11HEM1 is on a distinguished road
I have it too and I haven been in four times for the same thing. I had the foam "fix", The service manager told me I was hearing thing, Another dealer told me it was because of my dealer install mopar lift, REALLY, and another said he had a guy work on it for 4 hours "adjusting my doors. Yup still have it.
Debadged -4" Mopar Lift - XD Cranks - 325/60/20 Nitto Grapplers
Old 01-24-2012, 06:43 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Mine was prety quite till I installed the mopar window vent guards. Now I feel like the windows leak and are making tons of noise. If i hold my finger at the top rear of the drivers window some of the wind noise goes away. It's now worse in the back seat. I don't sit back their so I have not heared how loud it is in the back seat. Just what people tell me.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 01-28-2012, 02:03 AM
BlueBeastRam's Avatar
BlueBeastRam BlueBeastRam is offline
Vehicle: 2011 Ram1500 Big Horn Crew 4X4
Trim Level: 26Z Big Horn Regiona
Color: Deep Water Blue Pearl
BlueBeastRam is on a distinguished road
don't settle as most of you paid from 32 to 45k for your truck I had wind problems and they the dealership fixed it as a bulletin item no charge, they inserted two foam pieces inside the doors.
2011 Ram 1500 Big Horn Crew Cab 4X4 Deep water Blue pearl coat 5.7 Liter V8 HEMI MDS VVT
Old 10-26-2013, 11:25 AM
Falkirk18 Falkirk18 is offline
Vehicle: 2014 CC Longhorn
Trim Level: Longhorn
Color: White/tan
Rep:30
Falkirk18 is on a distinguished road
I purchased a 2014 Longhorn last week, and am too experiencing a buffeting noise from the drivers side A-Pillar area. Very annoying. And it gets worse as you increase in speed... At highway speed, I can hear it over the radio at significant volume.
As I've tried to determine what is causing it, I folded the side view mirrors in when the noise occurs (power folding mirrors), and it 100% disappears.
Anyone know how to fix the issue when it is the side view mirror causing the noise?
Thx!
Old 10-28-2013, 02:51 PM
taildragger taildragger is offline
taildragger is on a distinguished road
A little test I did was roll down the window when you hear it and pull the driver's mirror in, roll it up and see if it stops. I found out the whistling was sporadic but that was it. If that's not it, when you have a passenger with you get them to try it on that side it could be coming from there.
Wind Noise LadyRam Body & Interior 13 01-29-2012 11:09 PM
2010 Dodge Ram 5.7 quad cab wind noise back right passenger area quibbly 2010 Dodge Ram Forum 13 01-23-2012 06:53 PM
Noise with 2011 CC 2500 LB Blackthunder 5.7L (345 cu in) HEMI V8 Specific Topics 19 05-08-2011 10:55 PM
Wind Noise rbu1 2011 Dodge Ram Forum 12 11-26-2010 01:09 AM
2011 Big Horn and Outdoorsman RootBeer 2011 Dodge Ram Forum 6 10-21-2010 12:45 AM
