Old 01-30-2011, 12:06 AM
kingator's Avatar
kingator kingator is offline
Vehicle: 2005 dodge ram 1500
Rep:87
kingator will become famous soon enough
Cool How do you mount and wire YOUR lights behind grille?
Sooo How do you mount and wire lights behind YOUR grille what did you wire it to did you put a switch in the truck and then were did you put it and thanks
Old 01-30-2011, 02:18 AM
icephreaq's Avatar
icephreaq icephreaq is offline
Vehicle: 2008 Ram 1500 QC 4.7L
Rep:91
icephreaq will become famous soon enough
I got a set of Hella 500FF driving lights mounted behind the grille. I just followed the directions that came with the lights. I mounted the lights on the support that goes across the front of the radiator. Wiring was really easy with that kit. Tapped into the high beams and ran a switch to the dash just in case I want to turn them off while I have my highs on for some reason. (like that'll happen) The switch is mounted below the headlight switch. There was a small plastic plate on my dash that's used to mount something I don't have in my model truck so I just drilled a whole of the appropriate size for the switch that came with my kit.
Debadged and RamForumZ branded, 3bspec LED Tails (chrome), LED 3rd brake light, Putco 360 reverse lights, turn signals and tag lighting, blue LED instrument cluster, Hella 500FF driving lights, self installed OEM foglights, VOLANT CAI in route!
Old 01-30-2011, 02:32 AM
I agree..the Hella kits come with everything you need and are easy to wire up.
Mine are wired up and outside the truck but icephreaq has the right of it. The support in front of the radiator is the perfect place to mount them if you want them behind the grille.
My switches are in the cab, right next to the steering wheel on the left side of the lower dash cover.
Old 01-30-2011, 02:38 AM
icephreaq's Avatar
Rep:91
If you look at Maddog's first photo, my switch is mounted in the plate that his pedal adjustment switch is in the bottom left. :-)
Old 01-30-2011, 02:41 AM
Nice, icephreaq!
Old 01-30-2011, 02:23 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
My rectangular Hella 500FF's are mounted to the radiator cross member as well. The kit has all you'll need. The switch for my reverse lights is on the center console access panel (my gallery has a pic or (2)) but I ran these to a floor mounted foot switch (old school) that I screwed to the floor near the left side near the firewall. I'll try and get a few pics taken later if you'd like since I don't think I found the time to document/write up that mod over Christmas break.
Old 01-30-2011, 04:20 PM
kingator's Avatar
Rep:87
ya that would be great a foot switch would be great!!
Old 01-30-2011, 09:05 PM
I push the skinny pedal
Rep:3277
I don't have a switch. I mounted mine with a relay to my high beams as mine are driving lights, so when I switch to my highs, they come on.
Kurtis
Old 03-06-2011, 07:10 PM
BMAC BMAC is offline
BMAC is on a distinguished road
Does anyone have pics of the location on the holes for the lights themselves? Like so many inches from left ETC....
Old 03-06-2011, 08:47 PM
Rep:3277
There's no 'right' place to put them. Just measure the total width of the crossmember to find the center, then looking at the grille, try to find the middle of your opening (from the center of your grille). Take that measuerment and transfer onto the crossmember on each side.
Kurtis
HID INSTALL SOLUTION for anyone that cares silverbullet13 Custom Dodge Ram Interior and Exterior Lighting 3 08-26-2013 09:54 PM
