Old 01-16-2011, 09:53 AM
brewman brewman is offline
Vehicle: 1997 Dodge Ram 1500 4xr4
Color: Green
Rep:63
brewman will become famous soon enough
Default Instrument Panel Bulkhead Connector
In the attached picture is the instrument panel bulkhead connector. I'm removing my instrument panel and need to disconnect left side electrical connections - most of which terminate at the bulkhead connector.
I just want to make sure removal of the center bolt is how you disconnect the instrument panel harness from the bulkhead. It would be really bad if it actually was holding the pins in the connector assembly
File Type: jpg instrument panel left side main wiring.JPG (94.6 KB, 13 views)
Old 01-16-2011, 03:08 PM
Yes loosen up the bolt and seperate the connection . You'll be good to go .
Old 01-17-2011, 08:44 AM
Color: Green
Rep:63
Thanks for the confirmation. I figured that was the case, but wanted to be sure. The dash is ready to come out - probably later today.
