Old 01-14-2011, 01:20 AM
MADDOG MADDOG is offline
Rep:22
Default How Is My Truck Equipped?
Just go here, fill in the info and Dodge will email you your build sheet!
http://www.dodge.com/wccsapp/univers...ull&category=U
Kudos to our member, Valve, for finding this info!
Old 01-14-2011, 08:42 AM
I push the skinny pedal
Rep:3277
This IS good info!
Kurtis
Old 01-14-2011, 01:14 PM
Valve's Avatar
Valve Valve is offline
Vehicle: 2005 Dodge Ram 1500 Quad 4x4
Rep:141
Valve will become famous soon enoughValve will become famous soon enough
lol i feel like a heel,I found the info on this Forum.
Is very helpful especially for Used Ram buyers.
Line-X : Extang : Python 990 SSLCD : Tailgate Lock with Doors :
Fog Light Toggle Bypass : AeroTurbine at3030 : Tint match rear QC : SilentArmors on stock 20s(nitto and wheels in Future)
2005 Dodge Ram Service Manual
Old 01-14-2011, 01:17 PM
BlackBullet's Avatar
BlackBullet BlackBullet is offline
Vehicle: 2010 Ram Hemi TRX4
Trim Level: TRX4
Color: Brilliant Black Met
Rep:39
BlackBullet is on a distinguished road
thats some good stuff. thanks.
Leveling kit, DSP tuner, 14" MAGNAFLOW with side exit, heavy duty DODGE slush mats, DODGE bed mat,BILLET TECH catch can, STAINLESS steel door sills, K@N drop in filter, level ride airbag suspension....
Old 01-14-2011, 07:09 PM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Vehicle: 2011 ram 1500
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
I emailed them and got a response in two days... Its nice to have a complete list of what your truck has!
Here's mine
Sales Code Description
*M9 Cloth 40/20/40 Prem Bench Seat
-V3 Dark Slate/Medium Graystone
ADAP Light Group
AFZP Quad Cab Big Horn Value Group
AJB Security Group
APAS Monotone Paint
BABS 160 Amp Alternator
BCVS 700 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CBZS Prem Vinyl Door Trim w/Map Pocket
CGDS Front Height Adjust Shoulder Belts
CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags**
CJ2P Supp. Side Curtain Frt/Rr Air Bags
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CVHP Front Center Seat Cushion Storage
CVNP Folding Flat Load Floor Storage
CV1S Vinyl Shift Knob
CV2P O/Head Console w/Trip Computer/UGDO
DBAC All Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DH8P Elec Shift On Demand Transfer Case
DJMS 205MM HD Front Axle
DMH 3.92 Rear Axle Ratio
DRNS 245MM REAR AXLE
DSAP Anti-Spin Differential Rear Axle
DS7S Conventional Differential Frt Axle
EZH 5.7L V8 HEMI MDS VVT Engine
GACS Tinted Glass Windows
GFES Rear Power Sliding Window
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GNMS Passenger Side Sun Visor w/Mirror
GNZP Auto Dim Exterior Driver Mirror
GUKP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JATS Instrument Cluster w/Display Screen
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JFJS Temperature & Compass Gauge
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKVP 115V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPWP Power Lumbar Adjust
JP3S Pwr Front Windows, 1-Touch,Up & Down
JRTP Power 10-Way Driver Seat
LAZS Vehicle Information Center
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LDAP Underhood Lamp
LEBP Ext. Mirrors w/Supplemental Signals
LECP Exterior Mirrors Courtesy Lamps
LETS Traveler/Mini Trip Computer
LE4P Black Exterior Mirrors
LHEP Rear Dome w/On/Off Switch Lamp
LMEP Halogen Quad Headlamps
LMGS Automatic Headlamps
LNJP Fog Lamps
LPES Cargo Lamp
LSAP Security Alarm
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MENS Front Wheel Spats
MFHP Platinum Grille
MGAS Ram's Head Badge
MHLS MOPAR Rear Wheel Well Liners
MNES Body Color/Chrome Door Handles
MPLS Black-Out Tape
MPPS Rear Wheel Spats
MS2S Ram 1500 Badge
MUSS 4X4 Badge
MW5P Hemi Badge
MXCS Front Bumper Sight Shields
MYFP Bighorn Badge
NAE California Emissions
NERP Dual Rear Exhaust
NFX 32 Gallon Fuel Tank
NHDP Heavy Duty Transmission Oil Cooler
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PW7 Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RBZ Media Center 430 CD/DVD/MP3/HDD
RCGS 6 Speakers
RDDP Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
RFHP 6.5" Touch Screen Display
RSCS SIRIUS Satellite Radio
RSPP Uconnect Voice Command w/Bluetooth
RSUP Audio Jack Input for Mobile Devices
RSXP Remote USB Port
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHFS Rear Stabilizer Bar
SUAS Tilt Steering Column
TBMS Tire Carrier Winch
TBSP Full Size Temporary Use Spare Tire
TUKP P275/60R20 OWL All Season Tires
TZAP Goodyear Brand Tires
WF1S 17" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
WP2 20" Aluminum Chrome Clad Wheels
XAP Power Adjustable Pedals
XBMP Remote Start System
XBNP Tip Start
XBSS Pickup Box
XFH Class IV Receiver Hitch
XFKS 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XGDP Universal Garage Door Opener
XGMP Tire Pressure Monitoring Display
XJCP Locking Lug Nuts
XJJS Locking Tailgate
XJ8S Body Color Fuel Filler Door
XRFP 30GB Hard Drive w/6700 Song Capacity
X81S Instrument Panel Parts Module
X82S Door Parts Module
X83S Front End Parts Module
X88S Tire & Wheel Parts Module
X9AP For More Info, Call 888-539-7474
X9BP 1-Year SIRIUS Radio Service
YAAS Build To U.S. Mkt. Specifications
Old 01-14-2011, 08:01 PM
Yeah so what...you brought it forward again, I saw it and I firmly believe in giving credit where credit is due. Because you did it is now a sticky for everyone to see!
Ya done good, Valve.
Old 01-14-2011, 08:09 PM
Rkeytek's Avatar
Rep:210
yeah a big thanks Valve!
Old 01-14-2011, 08:56 PM
Valve's Avatar
Rep:141
This forum rocks.
Old 01-14-2011, 09:01 PM
Rep:4072
Very helpful, much appreciated Valve!
Old 01-14-2011, 09:04 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
Great hook up, thanks !
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
