Old 07-05-2011, 11:54 AM
xtremedurb00's Avatar
xtremedurb00 xtremedurb00 is offline
Vehicle: 2007 Dodge Ram 1500 QC BH
Rep:16
xtremedurb00 is on a distinguished road
I found this website for the HID kits and supposedly they make some specifically for out rams. Has anyone heard any good or bad things about them?
http://www.****************.com/
20% Tint,Magnaflow Y-Pipe & Exhaust,Jet 180 TStat,NGK V-Power,TB Ground,EFan,Superchips 3865, K&N 57
Old 07-15-2011, 08:51 AM
ricktech ricktech is offline
Vehicle: 2011 Dodge Ram
Color: Pearl Cherry Red
ricktech is on a distinguished road
Default HID issues
Last night I finally solved the issue on my new Ram 2011 HID lights going out. I had the Raptor Kit from DDM tunning with the thin balast.
The system worked well from February to June. Then when the temperature got hot the left side started flickering and then it would not come on. At some times all the Headlights and fog lights would not come on.
Solution
I read somewhere that they were using the THICK balast and they had no problems. I had an HID kit from my 2004 Ram that I removed when I traded my truck. The old rusty Thick balast is woking fine with the old bulb and the error correction adapter. I think the thin balast are not compatible with the new truck.
Hope this helps.
Originally Posted by draken View Post
Hey i got a 55w slim H13 h/l kit 10k from DDM tuning and mine work when the truck is off but when the engine is on, the lights stay on for like 5 secs then flash 4 or 5 times and shut off? Any suggestions on fixing this? Oh and i have a 2007 dodge ram 1500 quad cab
Old 08-20-2011, 07:44 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Thank god this is here. I just went out to my truck to tackle this and went WTF! haha
2011 Big Horn 4x4 -SnowWhite-
Old 10-21-2011, 02:37 PM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2011 Crew Cab 1500 Sport 4x4
Color: Black Pearlcoat
Rep:19
blackpearldodge is on a distinguished road
Originally Posted by bombadillo View Post
Wow, thanks for the tutorial on changing a freaking headlight. They had to make it so dang complicated. Just about every other car, I look behind the headlight, pull a wire a pop a bulb out but not Dodge!!! I'm probably not going to go HID after seeing this, but go with a Nokya or PIAA bulb instead just to make things easy.
Dodge isn't the only manufacturer that makes it difficult to change a freakin' light bulb. My previous vehicle (GMC Canyon) was also a challenge to change the bulbs. Unless you have very small, and dainty hands, changing the bulbs required removal of the grill and light assemblies. I can recall removing the first layer of skin on my right hand after ATTEMPTING to squeeze my hand behind the driver's light assembly. Once I got my hand in there (albeit a bit less skin), I just about didn't get my hand out! And I did this in October (temperature was around 6 degrees Celsius) so the metal was already cold to the touch. Colder temperatures = less feeling in fingers/hand!! LOL.
I wasn't too impressed with Dodge and their headlight removal/installation process, but once you've removed the lights the first time, everything is easier the second, third, etc., time around. And although removal of the grill isn't needed, I did just so I had 100% access to the headlights. I was going to magnetize my socket (but didn't have a speaker lying around)... that's why I decided to remove the grill. An extra long socket extension is pretty much all you need though (if you don't remove the grill.)
I'm tackling my kit installation this weekend. Hopefully everything works out.
Once you have Black you'll never go back!
Sport Performance Hood, OEM Mud Flaps, Engine Cover (Hemi Orange), Factory Spray-in Bed Liner, 50 watt - 6000k HID Headlights (low-beam), 35 watt - 4300k HID Fog Lamps, LED License Plate Lights
Old 10-29-2011, 11:01 PM
BlackJack's Avatar
BlackJack BlackJack is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4X4 Quad Cab
BlackJack is on a distinguished road
What is the reason now for grinding off the paint on the passenger's side? If it was working previously why would it not work after you install your HID? I looked and could not find the ground you mention for the passenger side.
Old 10-30-2011, 04:11 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
You do not have to remove the grill to take out headlights your making to much work use a 10mm on the top bolt and a 10mm with a long ext for the bottom bolt.
Just stick some duct tape in the socket and boom problem solved
Old 10-30-2011, 04:15 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
In my opinion do not use ddm there stuff sucks will work great but youll have problems with them used them with my stang 3 sets sent back used got my ram said ill give them a shot HAHA same b/s and crappy service use http://www.****************.com/
jj is the man and walks you through any problem try that with ddm
Old 10-31-2011, 02:20 PM
Rep:19
Or you can magnetize your socket.
If anybody is interested in a local supplier (in Edmonton), send me a PM and I'll give you the name of the supplier I purchased my HID kit from. He's also on eBay, but he'll give you a better deal if you buy locally.
Old 11-03-2011, 10:21 AM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Put the halogens back in. You are blinding everyone. You suck.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 12-12-2011, 04:45 PM
Combatmedic313's Avatar
Combatmedic313 Combatmedic313 is offline
Combatmedic313 is on a distinguished road
This is a great write-up. Missing having HIDs. This will probably be the first mod I do. Do the bixenon lights work well?
I feel like I'm diagonally parked in a parallel universe!
headlight
