Old 04-27-2011, 01:04 AM
Speed 1B Speed 1B is offline
Vehicle: 2011 Ram Sport 4x4
Trim Level: Loaded Sport
Speed 1B is on a distinguished road
Thanks guys for all the help.
Old 05-02-2011, 09:11 PM
Csark21 Csark21 is offline
Vehicle: 2011 Dodge Ram Big Horn Crew C
Csark21 is on a distinguished road
I followed this to the "t" in order to put my Sylvania Silverstar Ultras in my 2011 Ram. I didn't remove the grill, but I did undo the top screws and pop the bottom brackets off slightly. There are a few tabs on the insides of the headlamp assembly that need some extra clearance when removing. I put 4 new bulbs in for the highs and lows, and Sylvania Silverstars in for the fog lights. They aren't making a 9145SU anytime in the near future, so I had to compromise. I'll keep everyone posted on the 'perceived' improvement. Just waiting for it to get dark.
Thanks again
Old 05-06-2011, 01:16 AM
draken's Avatar
draken draken is offline
Vehicle: 2010 Dodge Ram 1500 CC Bighorn
Trim Level: Bighorn. SLT
Rep:19
draken is on a distinguished road
Hey i got a 55w slim H13 h/l kit 10k from DDM tuning and mine work when the truck is off but when the engine is on, the lights stay on for like 5 secs then flash 4 or 5 times and shut off? Any suggestions on fixing this? Oh and i have a 2007 dodge ram 1500 quad cab
Zone 6" Suspension with 5" rear, Bilstein 5100s, Toyo M/T 315/70/18, 18x10 MotoMetal 967s, Bushwacker Pocket Flares, Flowmaster 10 series, Diablo Trinity With Hemifever Tune, Drop in K&N Filter, Retrofitted headlights, 5k morimoto HID, 6k Fogs, Metal Tonneau Cover, Plastidipped Bumpers and Grille
Old 05-06-2011, 03:32 AM
woodmw's Avatar
woodmw woodmw is offline
Vehicle: 2009 dodge ram 1500 4x4 crew
Color: inferno red pearl
Rep:110
woodmw will become famous soon enoughwoodmw will become famous soon enough
draken: I am not for sure on your model (07'). I would give the guys at DDM a call. They have really good customer service. I would say that you prob. need a canbus setup. They should be able to help you more... sorry.
Old 05-06-2011, 03:37 PM
draken's Avatar
Rep:19
Its okay Thank you for trying, im going to give them a call
Old 06-11-2011, 08:47 PM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
Wow, thanks for the tutorial on changing a freaking headlight. They had to make it so dang complicated. Just about every other car, I look behind the headlight, pull a wire a pop a bulb out but not Dodge!!! I'm probably not going to go HID after seeing this, but go with a Nokya or PIAA bulb instead just to make things easy.
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
Old 06-21-2011, 08:55 AM
ricktech ricktech is offline
Color: Pearl Cherry Red
ricktech is on a distinguished road
Default DDM 55 Watt and computer issues
Have you had any troubles since you installed the DDM kit? I installed mine on my 2011 RAM early Frebruary and they worked great up until June. One light started flickering then it went completely out. I put a new Balast I had purchased (in case I installd the HIBeam HID). And It worked for a few minutes then when I restarted all the lights were not working. Now the lights work intermitently. Some days they work others they stop working. I am afraid they will not honor the warranty since I Drilled the covers for the Quad Lamps.
Any help would be greatly appreciated.
By the way I bought the adapter with the kit to prevent the computer error on the Dash. As I explained earlier it worked nicely for about 5 months.
Originally Posted by woodmw View Post
Here are the before and afters
BEFORE...
Attachment 13407
AFTER...
Attachment 13408
This was a 55 watt 8k slim ballast kit from DDM. It is a bi-xenon which means it has Hi and Low beams in one bulb (telescoping bulb).
Old 06-21-2011, 02:42 PM
tbeaton tbeaton is offline
Vehicle: 11 2500 4x4
Rep:14
tbeaton is on a distinguished road
after installing these in my friends fathers denali 1500 this weekend i was seriously thinking about it until i realized that the only way to do it is to disassemble half of the front end. thats really a poor design, you shouldn't have to take the truck apart to change bulbs. now i don't know what i want to do but i have to do something, the light output when i switch to high beams is garbage, i have better light with the fogs and lows on.
11 deep water blue 2500 big horn, 5.7 hemi, 4.10 gears, 6" bds short arm lift, 20x9 -12 offset kmc hoss black wheels, 37x12.5x20 nitto trails, n fab cab length nerf bars, banks muffler w/ lou's custom tubing, pocket flares, top gun customz dual steering stabilizer, mission sled deck.
Old 06-25-2011, 09:31 PM
kewlguy53403 kewlguy53403 is offline
Vehicle: 2011 Dodge Ram Sport
Rep:25
kewlguy53403 is on a distinguished road
woodmw, Did your DDM kit come with the battery connectors? I assume so. I just received mine and I have no battery connectors, lol. Might have a hard time getting these to run w/o power.
Raptor Step & Bed Rails | K&N | BakFlip HD | Halo Proj. LIghts | Recon Brake Lights | DDM HIDs | Big Rig Lights | Night Raider Taillight Bar | Volant CAI | Magnaflow 18 | MGP Caliper Covers | Lower Billet Grill | 20% Tint | Blistein 5100 @ 2.8 | 34" Tires | Dipped Chrome
Old 07-05-2011, 11:51 AM
xtremedurb00's Avatar
xtremedurb00 xtremedurb00 is offline
Vehicle: 2007 Dodge Ram 1500 QC BH
Rep:16
xtremedurb00 is on a distinguished road
Does anyone have the full HID setup for a 07 BH QC 1500? I've seen at least 3 different ways to do it. Headlights - 35W vs 55W, capacitors, resistors, canceler, etc. I'm not sure on what would be the way to go on the headlights. I'm going to put the 6000K or 8000K 35W in my fog lights but, I'm waiting to order until I figure out what to do with the headlights. Does anyone have a 06-08 Ram that has successfully completed this mod and has ran them for some time now with no issues???
20% Tint,Magnaflow Y-Pipe & Exhaust,Jet 180 TStat,NGK V-Power,TB Ground,EFan,Superchips 3865, K&N 57
headlight
