Old 01-13-2011, 03:30 AM
woodmw's Avatar
woodmw woodmw is offline
Vehicle: 2009 dodge ram 1500 4x4 crew
Color: inferno red pearl
Rep:110
woodmw will become famous soon enoughwoodmw will become famous soon enough
Default 55w 8k DDM HID Install on 2009 with dual headlights
Here is my install of the DDM 55 watt kit on my 2009 Ram. I have the dual lamp setup and this kit worked perfectly. I can not speak for the quad lamp setup but this was a simple straight forward install. No need for any extra harnesses or any can-bus canceller.
1. Remove the radiator protector.
2. Remove the 4 bolts holding the grille.
3. You will have to pull straight out at each bottom corner of the grille once the bolts are removed to free the grille. There is a snap clip at each corner holding in place.
4. Now you can start removing headlamps. There are two bolts in the front and one in the rear accessed by panel in fenderwell from tire side.
5. There is a white plastic tab that hold the headlight in place. Just lift up on the tab to be able to pull the headlight out. (note: there is still a snap clip holding it in place also, after lifting up on tab I recommend pushing from fenderwell side and pulling from front at the same time to remove the headlight.
Here is a picture of the locking tab.
Old 01-13-2011, 03:50 AM
woodmw's Avatar
Rep:110
Default continued...
6. Now you can install the new HID lamps in housings. I found that the new bulb did not fit very tight into the housings so I modified the seals slightly. I removed the rubber seal and placed an o-ring underneath and re-installed the seal to make a tighter fit.
7. Now install the wiring in the truck. First the Positive wire to the battery terminal.
Second the gound wire. I found the chassis ground was closer to the head lamp and the wires were very short that came with the kit so this worked alot better than the (-) terminal on the battery.
8. Next I mounted the Relay and the Slim Ballast.
9. Then I positioned the wiring.
10. Now on to the passenger side. My truck was slightly easier than stock due to the fact that I have the factory intake removed because of the aftermarket K&N intake setup, so you might want to just drill an access hole in the plastic here next to the intake hole. I was able to just run the wiring through the old factory intake hole. (NOTE: You need to drill a hole some where for the ground wire on this side. Make sure you grind any paint off to ensure you get a good ground here... I made that mistake and when I turned my lights on the passenger side did not work... grinded the paint down and on she came... just my 2 cents)
11. Final step before re-assembly (optional)
I took a bag and taped it over the old headlamp connector on the passenger side since it is not used with this kit to keep any corrosion out.
Old 01-13-2011, 03:53 AM
woodmw's Avatar
Rep:110
Default Results
Here are the before and afters
BEFORE...
AFTER...
This was a 55 watt 8k slim ballast kit from DDM. It is a bi-xenon which means it has Hi and Low beams in one bulb (telescoping bulb).
Old 01-13-2011, 05:22 AM
I have stickied this thread in the section. Excellent write up!!!
This deserves some beans!
Old 01-13-2011, 10:11 AM
I push the skinny pedal
Rep:3277
Great write up Probably one of the best step-by-step ones I've seen, very thorough. This deserves some
Kurtis
Old 01-13-2011, 10:43 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Nice writeup! Repped!
Old 01-13-2011, 01:30 PM
Rep:1625
Reps from me, as well! Nice writeup!
Old 01-13-2011, 03:01 PM
platinuminjected's Avatar
Rep:713
excellent write up!!!i wish this was up when i did my H.I.D's
Old 01-13-2011, 03:06 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Nice tutorial,
Dillon-aka, The Little Kid
Old 01-13-2011, 03:51 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Nice job thanks for the pics too makes it easy when you can "see" it. Rep for the great work
headlight
