Old 01-29-2012, 03:12 AM
Lifted 08 Lifted 08 is offline
Vehicle: 2008 Dodge Ram
Color: Multi
Lifted 08 is on a distinguished road
Any more information on this? The pictures are kind of sketchy....
Old 01-29-2012, 03:57 PM
ShiftJockey's Avatar
ShiftJockey ShiftJockey is offline
Vehicle: 2007 Ram 1500
Color: Gray
Rep:48
ShiftJockey is on a distinguished road
I don't think you need to go to the lengths 07 owners do to install a catch can. Isn't your PCV system external to the engine?
Upgrading one part at a time.
Old 01-30-2012, 06:00 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
08 and older hemi intake manifolds are internal and cannot use a catch can unless you modify them. Now if you swapped to a new 6.1 manifold then you could add a catch can. But im sure there is some mild modifications needed to do that. But at least you would see a performance increase. The only down side is now you would also have to fabricate yourself a new intake tube aswell and in the end would probable have about 600-700$ tied into the swap maybe 500$ if you got everything dirt cheap. Or you could swap to a stock 09+ plastic eagle manifold instead of a 6.1 which might save a few bills.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 01-30-2012, 10:55 PM
I push the skinny pedal
Rep:3277
Cost to date on the 6.1L intake manifold swap is around $1100. That's a manifold, adapter spacers, LMI CF hammer intake, catch can, and hose upgrade. I went a step further and got a set of eagle heads for $600 so I won't need the spacers.
Just drill out the valve cover and add a catch can, saves you a WHOLE lot of money.
Kurtis
Old 04-10-2012, 04:07 PM
07HemiRam's Avatar
07HemiRam 07HemiRam is offline
Vehicle: 2007 Dodge Ram
Trim Level: Quad Cab
Rep:17
07HemiRam is on a distinguished road
Have you drilled out your valve cover and added a catch can? If so can you post some more pictures?? I would like to do this! When I changed out my factory throttle body I was not pleased to see how much oil was built up on it
6000K Bi-Xenon Headlights, 8000K Xenon Fog lights, Superchips Flashpaq, Magnaflow cat-back exhaust, Flowmaster y-pipe, Composite BFI with Amsoil dry filter, Flex-a-lite electric fan, 180* JET thermostat, 85mm Fastman throttle body.
Old 02-08-2013, 11:51 AM
kittpowell1's Avatar
kittpowell1 kittpowell1 is offline
Vehicle: 2004 ram 1500
Color: red
Rep:17
kittpowell1 is on a distinguished road
I have a 04 what does this catch can do? Is it like how the newer diesels have the egrs on them?
Old 04-20-2013, 07:03 PM
RamMan86 RamMan86 is offline
Vehicle: 2001 Dodge Ram
Color: Grey
RamMan86 is on a distinguished road
as posted above, I would also like to know more about somehow adding a catch can for my 07. don't really want to dump that kind of $ to do so.
Old 04-20-2013, 07:13 PM
02 Ram 02 Ram is offline
Vehicle: 02 Dodge Ram/92 IROC R/T
Trim Level: SLT Quad Cab
Color: Forest Green
Rep:67
02 Ram will become famous soon enough
i know, not the same engine but same concept. this is how we do it on our 90's turbo dodge cars. we have a PCV valve setup but it doesnt vent very well
2002 Dodge Ram 4.7L
1992 Dodge Daytona IROC R/T 2.2 Turbo
Old 04-20-2013, 10:50 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
otter1363
Old 04-21-2013, 12:12 AM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
That cai is awesome!!!
SPONSORED BY
BULLY'S PERFORMANCE
