Old 07-18-2012, 09:48 AM
WhiteKnight's Avatar
WhiteKnight WhiteKnight is offline
Vehicle: 2012 Dodge Ram Crew Cab
Trim Level: Express 4x4
Rep:13
WhiteKnight is on a distinguished road
Only slight rubbing but i fixed this problem real easy.
Black steps | 5% limo tint | De-badged | Wedge Toolbox Lline-X sprayed inside and out | Bilstein 5100 set 2.8| 20x10 Fuel Hostage -24 offset | 35x12.50 Toyo MT | Tinted tails and third break lights | Black exhaust tips | Fold A Cover Tonneau Bed Cover | Tow Hooks
Old 07-18-2012, 12:31 PM
Care to elaborate on that?
Old 07-18-2012, 10:19 PM
Rep:13
Try looking at this thread and see if it helps you out any.
http://www.ramforumz.com/showthread.php?p=823321#post823321
Old 07-19-2012, 12:53 AM
Saw that shortly after I asked
So you have no rub whatsoever with that tire size considering you only leveled and had to do a minor tweak on the fender?
Where did you get your rear window sticker?
I like it
Old 07-28-2012, 07:22 PM
jc0311 jc0311 is offline
Vehicle: 2012 Ram 1500 4x4
jc0311 is on a distinguished road
BDS 4 inch lift
Bilsteins 5100 in front
Fox racing shocks in the rear
Toyo M/T 35x12.5/20
Fuel revolver 20x10 4.5 BS, -24 offset
Old 07-28-2012, 08:07 PM
jc0311, absolutely nice lift....
Are your Bilsteins still set to 0 or are they somewhat lifted too?
It may be the angle but it looks like there is still a rake.
Either way, I like rake
Old 07-29-2012, 09:44 PM
LonghornRam12's Avatar
LonghornRam12 LonghornRam12 is offline
Vehicle: 2012 Ram 1500 Laramie Longhorn
Color: White/ Gold
LonghornRam12 is on a distinguished road
Great looking truck. How you like the fox racing shock? Perfect ride height, not too high, not to low..
Old 07-29-2012, 10:08 PM
Thanks for the compliments guys. The ride is pretty good, I know a lot of people say its better than stock but it is. I'm going to raise the bilsteins up a little bit in the front so it sits perfectly level. I opted for the 3" coil spring raise in the rear.
Old 08-07-2012, 12:18 AM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Here's my setup on my new Ram 2500. I have the 5 inch Rough Country lift, 20x9 KMC XD Spys with 4.5 inches of backspacing and 355/60-20 (37x14.00) Nitto Terra Grapplers. Due to the width of my tires, I had some minor rubbing on my plastic wheelwell liners and splash guard. I did some minor trimming on the OEM splash guard and used a plastic zip tie to pull the wheelwell liners back about 3/8 of an inch.
Old 08-07-2012, 12:32 AM
Wandell, once again, you have a mean truck!
That stance is fantastic.
Will you be getting flares?
lift, setup, tire, wheels
