Old 02-16-2014, 02:11 PM
Coastie89 Coastie89 is offline
Vehicle: 2013 Dodge Ram
Trim Level: SLT/Big Horn
Rep:32
Coastie89 is on a distinguished road
Any recommendations on a speedo calibrator
Old 02-16-2014, 02:29 PM
Hypertext on the cheap or diablo/Bully's dog on the more $$ But more features.
We can set you up with either
click here --->***Tuner and Muffler Sale*** <---click here
Old 02-17-2014, 01:51 AM
macc08's Avatar
macc08 macc08 is offline
Rep:722
get the Trinity T-1000...
its the best (speedo calibrator) among other things, lol...
Old 03-04-2014, 10:08 AM
ty-wa's Avatar
ty-wa ty-wa is offline
Vehicle: 2014 Ram 1500
Trim Level: Tradesman/ Express
Color: Blue Streak
Rep:88
ty-wa will become famous soon enough
Default 06 Ram 2500
Blistien 5100 set up, stabilizers, relocator and leveled. About 3 inches in the front with this combo.!
No rubbing, except on the mud flaps. (Which will be removed for flares once the weather permits)
35x12.5 R20 Micky Thompson ATZ with BMF Novakanes in Death Metal Black.
-Ty-wa(Z) here
Old 03-27-2014, 12:43 PM
hotmach hotmach is offline
Vehicle: 2006 Ram
Rep:15
hotmach is on a distinguished road
Hey all, you have great looking trucks !
I just purchased a 2012 Ram 2500 5.7L 4x4 Crew/long box 3.73 gears. After reading through this whole thread it seems the average is at least a front end level and 35's. I'm not sure i want to go so big as i tow a 35ft travel trailer and don't want to greatly effect the trailers tow level and mess with my gearing. My older 1500 truck (3Gen) has 33s Toyo m/t's and -12's wheels with no lift, has worked well on that truck. I did like it's appearance too.
Keeping similar sizing, will 33's look to small on a 2500 ? If anybody can post pics of 33's/18's it would really help. 265/70/17's are whats stock on there now. Should i be concerned about the gear ratio using 35's ? i'm thinking yes as i will be pulling on some pretty good grades,but would love to hear your thoughts.
Thanks in advance.
Old 03-28-2014, 08:38 PM
macc08's Avatar
Rep:722
Thanks in advance.
You would be fine with that setup. I dont think the Toyo M/T's will look too small. Probably look perfect. And that gear ratio with the level and tires will pull just fine!
A lot of us here (including myself) have a level and 35" M/T's with 3.55 gears. I can still spin my tires no problem, so with that little bit of extra gearing, you shouldn't have a problem hauling, especially if you stick with 33"
Hope that helps!
Old 04-11-2014, 09:45 AM
Drti Drti is offline
Vehicle: 2010 ram 2500 Laramie
Trim Level: Larime o
Drti is on a distinguished road
Need advice on tire/rim setup..
I'm looking to level my truck, I wanna go 20 inch rims with the biggest tire and would like to poke out a lot..
Thanks dan
Old 04-11-2014, 09:51 AM
Thanks dan
Then the question is....are you able and capable of trimming/modding your fenders to fit tires that 'poke out a lot'?
Biggest tire also coincides with what level height you do.
2" level, max safety and looks wise is 34"
2.5" level, you can do a 35"
Poke out a lot?
20x9, 0 offset = 1.5"
20x9, -12 offset = 2"
20x10, -12 offset = 2.5"
20x10, -24 offset = 2.5"
20x12, -44 offset = 4.5"
You can run any of the 20x9 to 20x10 depending on whether you want to trim/bend things in your fender to fit them
Have a look at WhiteKnights thread (I believe its linked in the initial posts)
He has 2.75" Bilsteins (possibly settled to 2.6-2.65) and has full size Toyo MT on 20x10, -24 rims.
You can see exactly what he did to fit it
Old 04-11-2014, 09:54 AM
Poke out a lot?
Ok thanks for the info... Cheers
Old 04-11-2014, 02:33 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Thanks dan
The Guide to Leveling & Wheel and Tire Sizing linked in my thread will have lots of information for you. It also has a link to whiteknights wheel and tire thread in it running the 20x10 -24 offset rims and 35x12.5's.
lift, setup, tire, wheels
