Old 01-28-2014, 01:03 PM
Originally Posted by RAM357 View Post
Personally I pick flares last. I start with lift, then move to what wheels place my 35" tire where and ask myself just how far out I want the tire to sit, and THEN I move on to choosing flares. (If it were me , and I was looking at getting a 4" lift/35 rubber)
Some members here can assess this down to the nearest 1/4" or better.
If you do go with pocket flares, then I'd want to know my tires are going to at least be even with them, but ideally out an inch or so. That would give a nice look. If your tires are too inboard with such huge flares, to me, that always looks odd - like things weren't incubated long enough before execution.
Var
Var is spot on with the flares....buy them after or during the process once you know EXACTLY what rim you want to run.
Nothing worst than seeing you rims tucked under or extended WAY past the flares if you are wanting flush or near flush
Old 01-29-2014, 05:28 AM
omarP omarP is offline
Vehicle: 2014 ram 1500 4x4
Trim Level: tradesman express
omarP is on a distinguished road
love the truck! thats the look I'm going for! sorry but i don't kno anything about lifts! i kno that bilstiens are shocks rite? but did u lift ur truck wit only those shocks? or do you have those shocks plus a lift kit or leveling kit?? sorry for the dumb questions (talking about post #544)
Old 01-29-2014, 08:09 PM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Hi OmarP,
That post is a page back...
Here is a quick tip that will you get an answer to questions like this, and it also helps people understand what you're talking about.
Tip:
Anytime you come across a post such as post #544, that you wish to comment on, simply click on the QUOTE button below that particular post and it will open up a REPLY box with that post (544 in this example) already inserted.
Next just type your question below that quotation!
Hope this helps you in the future
Var
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 01-30-2014, 08:23 AM
hemidave hemidave is offline
Vehicle: 2010 Ram 1500 4x4
Trim Level: SLT Sport
Color: Inferno Red
hemidave is on a distinguished road
Ok guys here is what I found....I cant find a 0 offset wheel the closest I could find was a +18. The guy at my offroad shop said he would not guarantee it not to rub. So until someone that has done what I want to do can tell me that this or that wheel will not rub im on hold. I can not stand rubbing! I went through it with my last truck and it drove me up the wall! LOL!!
David
2010 Ram 1500 4x4 Inferno Red Sport. Yep.....It's Got A Hemi!!
Old 01-30-2014, 01:16 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
You aren't going to clear a 35x12.5 tire on a +18 offset. It will rub on the upper A-arm for sure. Which isn't even a rub you can deal with if you wanted to, it will tear your tire apart.... So your options are to either downsize your tire or run 1/4" wheel spacers.
Old 01-31-2014, 06:58 AM
Color: Inferno Red
I just got to find a wheel that has a -12 offset. I just cant find one I like. There all black and I want a chrome. Thanks!
David
Old 01-31-2014, 07:24 AM
holydiver89 holydiver89 is offline
Vehicle: 2012 Dodge Ram 5.7 HEMI QC
Color: Brilliant Bright White
holydiver89 is on a distinguished road
Stick with positive offset, 0 at the MOST to keep from rubbing. That -12mm will stick out like 2" and rub like crazy. If you wanna run a 9" wide rim with 35x12.5 tire stay close to 0. Factory flares look nice and tires will stick out just a tad also husky makes mud flaps designed for factory flares
Old 01-31-2014, 01:27 PM
Rep:2026
Tons of options out there for chrome rims. Where are you looking? Check out companies like Fuel Offroad, XD, or BMF. All make chrome wheels. Most companies make each line of wheels in both black and chrome. Do you have a specific wheel you're looking for?
-12 offset on a 9" rim won't rub like crazy. Maybe slightly depending on the tire and level size... but it's easily fixed with very minor work. But yes, 0 offset does give less of a chance of rubbing.
Old 01-31-2014, 07:46 PM
Color: Inferno Red
I think I found the one I want. Eagle series 079 20x9 -12offset
In all the looking I have done I can not find a 0 offset wheel I like
David
Old 02-04-2014, 05:40 AM
bilstiens 2.8
rcx rear 1.75 coil spacer
bilstien rear 5100
rcx 1.25 bl
cooper stt 35x12.50x20
factory 20x9
motorsport tech 10mm hub/wheel centric spacers
(highly recommended over 1/4" universals)
mopar 2500 fender flares painted to match
mufflex 18
intune dcx[/QUOTE]
lift, setup, tire, wheels
