United Radio
Old 11-18-2013, 08:55 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1990
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
Originally Posted by Slawitschkafam View Post
2014 tradesman 4x4. If I go with a 2" level kit what is the biggest tire I can put on a 20" XD Misfit wheel with no rubbing?
Thanks
I'd recommend a 295/60/20. That will look the best with that set up IMO.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover | 5000K Morimoto HID's (lows and fogs)
Old 11-19-2013, 03:53 PM
daviddup78's Avatar
daviddup78 daviddup78 is offline
Vehicle: 2012 Ram 1500 HEMI 4x4
Trim Level: Lone Star
Color: deep cherry red
Rep:71
daviddup78 will become famous soon enough
i had the ready lift on my front it did ride good but my rear was still 1.5'' higher, put the bilsteins set at max on my front, rode even better and looked better. now i have the fabtech 6'' lift with the bilsteins set at 1.4
2012 Dodge Ram 1500 4x4 with goodies and 6'' Fabtech lift
Old 11-19-2013, 05:30 PM
David, what tire size are you running?
Old 11-19-2013, 05:51 PM
daviddup78's Avatar
Rep:71
295/60R20 Nitto Trail grapplers, on +18mm offset moto metal 959 rims, it does rub, my friend has some 295/65R20 Nitto Trail Grapplers on factory wheels, and no rub
i would do the 295/65R20 if i was to just a front level kit. that's my preference though
Old 11-24-2013, 09:19 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1101
That looks amazing, David. Well done.
Simon
Old 11-29-2013, 08:23 PM
dougellison94's Avatar
dougellison94 dougellison94 is offline
Trim Level: laramie longhorn
dougellison94 is on a distinguished road
Originally Posted by ty-wa View Post
Beautiful truck!!!!
Thanks man! Yours is pretty sexy too!
Old 11-29-2013, 09:27 PM
daviddup78's Avatar
Rep:71
well mine dont rub now with the lift bec i put some 1.75" hub centric adapters but just with the level kit mine rubbed
Old 12-03-2013, 10:18 PM
twiceborn twiceborn is offline
Vehicle: 2011 Dodge Ram 1500
Color: Blue
twiceborn is on a distinguished road
Hey guys, I have a stock 2011 Ram, no lift or leveling kit. I want to drop down from the stock 20's to 17x9's. What would be the absolute largest tire I could put on the truck without any rubbing or clearance issues? I was going to go with 285/70/17's but wasn't sure if I could go any bigger? Thanks
Old 12-09-2013, 01:15 AM
Campbell402's Avatar
Campbell402 Campbell402 is offline
Rep:73
Campbell402 will become famous soon enough
If your going to stay stock I think the 285/70/17 is going to be the largest you can fit. If you get a level kit you could go up to 35 12.50 17
Old 12-09-2013, 02:08 AM
Rep:1990
Check out the guide to leveling and wheel and tire sizing linked in my signature below
lift, setup, tire, wheels
