Old 08-17-2012, 03:21 PM
Originally Posted by Drex851 View Post
Gotcha, so grab the 5125's correct? Figured while I have it all ripped apart I might as well throw them in
Yes, but you need to know which ones to grab as they come in different lengths.
I would suggest just running the shock that comes with the RCX kit first and see if you like it.
Swapping the rear shock is a DIY that can ben done later.... IMO
Old 08-17-2012, 03:26 PM
Drex851 Drex851 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Slt
Color: Grey
Rep:21
Drex851 is on a distinguished road
Sorry a little confused, 5100's for the front and if I want 5125s for the rear correct?
Old 08-17-2012, 03:34 PM
Correct!
The 5100's can be adjusted up to 2.8 (increments of 0, 0.7, 1.4, 2.1 and 2.8) the rear 5100 cannot be extended....but it can accommodate a 1" spacer and will allow for a 1" longer throw
5125 is a longer shock and they have sizes depending on your requirement
IMO, stick with the 2.2 shock that the kit comes with and run the Bilstein 5100 up front and adjust as you want
Hope this helps
Old 08-17-2012, 03:55 PM
Trim Level: Slt
Color: Grey
Rep:21
Gotcha, sorry for all the questions and thankyou again
Old 08-17-2012, 09:39 PM
No worries man! That is what the forums are for
Old 10-10-2012, 12:03 AM
1ofakind's Avatar
1ofakind 1ofakind is offline
Vehicle: 2014 Ram 1500
Color: maximum steel
Rep:13
1ofakind is on a distinguished road
hi guys, just wondering what tire size you would recommend for my 2012 ram 1500. im going to do the bilstein 5100 adjustables, and some 20" black rims, not sure which ones yet. so id like to go as tall as i can and wide as i can so might need some recommended offests for the wheels also. thanks!
6k Lows & Fogs / 40" SR / 308's / 325 60 20's / Husky Mats / 5% Tint / Debadged / Wrapped Dash / 2" Level / Ez-Down /
Old 10-10-2012, 07:08 AM
I would look at Nitto Terra Grappler in 295-60-20
If going with aftermarket rims, I would do 20x9, 0 offset or 20x10, -12 offset. Both are 5" backspacing
Old 10-11-2012, 12:21 AM
1ofakind's Avatar
Rep:13
ok thanks! i was looking at the wrangler duratrac for tires since we get tons of snow in alberta and i had these tires on a previous truck and perform well i thought. anyways! i plan to do some fender flares also so what is a good offset with the recommended tire size you gave me to get a nice wide stance? or am i pretty safe with that tire size to do whatever offset?
oh and btw BEAUTIFUL truck you have! Finally debadged my truck just a little while ago and seems to look pretty good but it is dark out so hopefully it turns out!!
Old 10-11-2012, 11:25 AM
What flares will you be running? Pocket? OE?
If OE you want 20x10, -12 offset
if Pocket you want 20x10, -24 offset
Old 10-11-2012, 10:45 PM
1ofakind's Avatar
Rep:13
going to go with the pocket style busch wackers
lift, setup, tire, wheels
