Old 08-15-2012, 06:09 PM
Originally Posted by Ksmith View Post
Stock wheels and 35-12.50-17
After wheels and new 35-12.50-17 toyos
But you can't see the Ranch Hand bumper
That is one bad ass ram
Old 08-16-2012, 03:23 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Nice Mega Cab man!
Old 08-17-2012, 11:31 AM
Drex851 Drex851 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Slt
Color: Grey
Rep:21
Drex851 is on a distinguished road
Default need help with offset
Hey how's it going guys, a little new to the forum, so I'm doing a 6" rcx lift with 37" nitto terra grapplers, which they say are 1"-1.5" wider then the trail grapples, my question is can I get away with a -12 offset or do I need a -24 and how far does the -24 stick out past the fenders? I'm also doing the bilstein 5100, s
Old 08-17-2012, 11:44 AM
You will be ok!
What is your rim width and size?
I have a 20x9, 0 offset with 37 Trail Grapplers and mine is 1" away from the A arm
But I wanted it tucked more.
-12 will prob give you the same clearance as mine as the Terra's, which are wider (slightly) as you stated
Old 08-17-2012, 12:39 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
You will be fine with a -12 offset like FastNugly stated.
Old 08-17-2012, 01:00 PM
Trim Level: Slt
Color: Grey
Rep:21
I'm doing the 20x10 fuel throttle rims, 1 more question, did u guys do the 1" lift on the rear bilsteins, and thankyou very much for the help btw
Old 08-17-2012, 01:15 PM
Wheels will fit for sure.
Many have ran that width of rim with 13.5 Toyo MT's and those have side teeth and are 14" wide.
So wheels will not be an issue.
You mentioned lifting though... with the 6" RCX kit.
That is the exact same kit I had installed this week. actually 2 days ago
Im guessing you are talking about the Bilstein 5100's for the rear? They wont work. They will only work on a Bilstein leveling but not a lift plus Bilstein in the front.
The shocks are too short...
I too bought the 5100's and will be returning them. Returning the rears that is.
Run the 2.2 shocks that come with it and if you don't like it or when it wears down, switch to the Bilstein 5125 for a longer length. They have one that is 14" in length and that is what you need.
Old 08-17-2012, 02:40 PM
Trim Level: Slt
Color: Grey
Rep:21
Oh ok, yea cause everything I read says to get the 5100s cause there the best
Old 08-17-2012, 03:10 PM
They are good!
But if you are lifting, just grab the front 5100's.
Old 08-17-2012, 03:16 PM
Trim Level: Slt
Color: Grey
Rep:21
Gotcha, so grab the 5125's correct? Figured while I have it all ripped apart I might as well throw them in
lift, setup, tire, wheels
