Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 12-08-2010, 08:20 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Default When the MDS Functions Per the Engineers
Here's more from the Engineers.
MDS will function when the engine speed is between 1000 and 3000 rpm, and the engine is hot. Then whenever the torque required to move the vehicle is able to be met with 4 cylinders the engine will switch to MDS mode.
Edit: they added that in order to tell if MDS is on/kicked in the ECO light on the EVIC will show. Therefore, no need for any kind of MDS light.
Brian:
Old 12-12-2010, 09:26 PM
Good info, Brian!
Old 12-22-2010, 02:47 PM
xploded xploded is offline
Vehicle: 2009 Ram 1500 Crew Cab 2wd
Color: Two-tone Red/Stone
xploded is on a distinguished road
Thanks.
Is an "ECO" light the same as a "Fuel Saver" light? I have an 09 and fuel saver comes on all the time, but I have never seen ECO.
2009 Ram 1500 Crew Cab 2wd Laramie
What else I've done: http://www.cardomain.com/id/xploded1
Old 12-22-2010, 02:59 PM
Color: RootBeer
Rep:1287
Should be the same thing. Easiest way to know for sure is to look at the RPM and whether you're not accelerating but just maintaining speed.
Brian:
Old 12-22-2010, 04:34 PM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
Ahh soo much answered.. so the ECO light in the Evic IS on in mds mode. That's the only clue I have when MDS is on. I can't tell from sound or anything. I dont have the growl or groan as some say they hear when its on. I guess Im lucky to not hear it. I do notice when it is on it takes a little bit to kick back into all 8 when I have to do evasive maneuvers.
Good find Brian.
Old 01-19-2011, 01:55 AM
JRI JRI is offline
Vehicle: 2010 Ram Crew Cab
Rep:14
JRI is on a distinguished road
There have been posts on this that say the ECO light does not always mean the the vehicle is running on 4 cylinders but that you are simply driving in a fuel efficient manner.
So am I to take this as the latest and official word that the ECO light means that the vehicle is only running 4 cylinders when it is on?
Old 01-19-2011, 02:03 AM
Color: RootBeer
Rep:1287
That's what the engineers said.
Brian:
Old 02-08-2011, 06:43 PM
chadob69's Avatar
chadob69 chadob69 is offline
Vehicle: 2009 Dodge Ram 2WD
Color: Blue
chadob69 is on a distinguished road
I have never seen any such light. I have an 09 also but have never seen any indication that MDS has kicked in. I have all highway drive to work(about 15 miles) and have never seen it. Is there a way to turn it on and off?
Old 02-10-2011, 02:18 AM
Color: RootBeer
Rep:1287
If you are driving in D not 5 it will appear at the top of the display centered in your dash above the steering column.
Its not on in this pic, but it would be between the NE and 85F. That is if you have a 1500 1/2 ton.
Brian:
Old 02-10-2011, 04:18 PM
I have learned in a different thread in here that our 09's do not have an ECO light and instead have a "Fuel Saver" light. I have been told they mean the same exact thing. The fuel saver light is also on the EVIC and the light come on at the lower right corner of the EVIC instead of the top center.
If you do not see the fuel saver light ever, I believe you may need a reflash of your ECU at the dealer to remedy that. Search around in here, and you will find threads discussing the new ECU flash.
