Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 01-11-2011, 03:26 AM
polarihog's Avatar
polarihog polarihog is offline
Vehicle: 2011 Dodge Laramie 4X4
Color: Black Metalic/ Gray bottom
polarihog is on a distinguished road
Send a message via Skype™ to polarihog
for some reason I don't think thats right on an 08..tow button still allows the MDS function..or at least I've read this on the forums from these sites. I do use the tow button almost all the time and it still goes into this ' flat 'spot that makes me push the gas a little bit harder to make it move with less lug when I need it...
Old 01-11-2011, 04:33 AM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
You just won't get overdrive if you keep it in 5th.
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 01-11-2011, 09:09 AM
Flaminchiten Flaminchiten is offline
Vehicle: 2010 Ram 1500
Rep:42
Flaminchiten is on a distinguished road
5th is overdrive, it is only a 5 speed transmission. I think you won't get the torque converter locking up if you leave it in 5th. If I am in D and put it into 5th then my revs climb slightly I assume this is the torque converter unlocking, since there is no 6th gear
Old 01-11-2011, 09:42 AM
iRESQu iRESQu is offline
Rep:2217
Thank you for the posting, Brian. I just came across this and I am not real pleased with the MDS either. We had been told to use the tow haul method.
Old 01-11-2011, 03:05 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Nope. I originally thought the tow-haul method turned off the MDS too. But when I attended the Engineer chat I learned the correct way to do it without using a programmer like the Predator.
Brian:
Old 01-11-2011, 05:30 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
This is correct, There is no MDS with the tow mod or OD on a 08 ,the risen you have to hit the gas a little harder sometimes is when it hit in that 5th gear and when you try to accelerate it takes a good push down on the gas to kick it down.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 01-11-2011, 06:32 PM
polarihog's Avatar
Ok.. I'll try this and see how it goes... Thanks...
Old 01-15-2011, 10:31 PM
ewb's Avatar
ewb ewb is offline
Vehicle: 2013 dodge ram cc
Rep:171
ewb has a spectacular aura aboutewb has a spectacular aura about
Excellent info
Walter
Old 01-15-2011, 10:40 PM
Good to know .
Old 01-18-2011, 07:28 PM
Color: RootBeer
Rep:1287
That's not quite correct. Fifth is an actual gear. Putting it in manual mode takes away the MDS. Hitting the Tow/haul button takes off O/D which is electronic.
This is for those that have the ability to switch to a manual shift mode. If your Ram doesn't have that option, then I do not know how to turn off the MDS.
I originally thought using the Tow/haul button did it but was corrected during the Engineer chat which I why I made the original post in this thread.
Brian:
