Old 12-05-2010, 07:24 PM
B and B LANDSCAPES B and B LANDSCAPES is offline
Vehicle: 1999 Dodge Ram 2500
Trim Level: base
B and B LANDSCAPES is on a distinguished road
Thumbs down abs light, brake light, speedo not working, stalls when stopping
Ok..... 99 Ram 2500 4x4 RWAL
The other day my abs light came on, then every third time or so I would start the truck also the brake light. Then the speedo quit....
Then went also 3 miles two days ago with everything fine then abs, brake, check engine lights all come on and speedo quit.. had friend try his cheapo abs scan tool and no avail (didnt think much about it then) used obd scanner and it threw a 500 speed sensor code...
so today i replaced speed sensor and disconnected the battery for 5 mins and key on ign and abs light on.... and about every 5 times keying ign the brake light stays on too.
neighbor hooked up motis....... no communication, tried 3 times with motis
took it for a drive and abs light and no speedo.....
What would cause no communication with motis? Come on RAM TECH...... you have been helpful so far.
Old 12-06-2010, 07:36 AM
Rep:1882
I presume you're talking about a Snap-on Modis. Is the communication problem just with the ABS module or all modules in the truck?
Old 12-06-2010, 07:47 AM
Trim Level: base
just the abs system it had no communication with..... it did communicate with the truck itself (check engine light)(it wasnt on but did say it was communicating)
so to answer your question- just the abs system
Old 12-06-2010, 07:54 AM
Rep:1882
I'm looking at the diagnostic tests and it's either going to be a wiring problem or an ABS controller problem.
Old 12-06-2010, 08:00 AM
Trim Level: base
im leaving to the shop in an hour and have no internet there..... what all can i look at wiring wise? funny you said that cause when it fist acted up it sort of went on and off with bumps a few times or one time i would start truck and it was on and i could shut it off and restart and it was off then i would hit a bump and it would come on right after the bump.
Old 12-06-2010, 08:07 AM
Rep:1882
Check the ABS fuse for looseness or corrosion. Check the connection on the ABS controller for the same thing. Look at the wiring for any signs of chafing or shorting.
Old 12-06-2010, 08:13 AM
Trim Level: base
i already checked the fuses and most wiring... the module is located under the knee panel right?
Old 12-06-2010, 08:22 AM
Rep:1882
The ABS module will be under the hood near the master cylinder. Follow the brake lines from the master cylinder and you'll find it.
Old 12-06-2010, 08:25 AM
Trim Level: base
i know that much lol..... but was told that there was some kind of module controller under the dash too that has to do with the system
Old 12-06-2010, 08:30 AM
Rep:1882
There's no module for the ABS other than the one under the hood.
