Old 11-20-2010, 01:01 AM
Aries's Avatar
Aries Aries is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Aries is on a distinguished road
Default Fog Lights not working??
Hi Everyone, Today on the way home from work I noticed that the light on the left hand side beside the speedometer, wasn't coming on when it was dark enough for the head lights to come on. But the head lights were on. So I figured I'd wait until tonight when it was dark out to see if it was just not dark enough out to make the light come on.
Well, that light doesn't come on anymore and my fog lights don't work anymore either???
Anyone have any ideas what I should check??
BTW I had the truck in for it's first oil change. and at the same time had the winter tires put on and an alignment done Could they have accidently hit something to stop the lights from working?
Any help will be greatly appreciated
Thanks
Tom
One other thing i have tried was pressing the square switch to the lower left of the headlight switch. It turns a yellow light on in the lower instrument panel that looks like would indicate that the fog lights were on. But they still don't work.
Old 11-20-2010, 01:30 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Not sure what could be wrong with the fogs however the little square button and the yellow light is for your cargo light.
Old 11-20-2010, 09:40 AM
Aries's Avatar
Thanks RansRAM! I'lll have to check to see if that light is working.
Anyone know where the fuse is for the foglights?
Old 11-20-2010, 11:52 AM
deepblue's Avatar
deepblue deepblue is offline
Trim Level: Quad Cab Sport
Rep:65
deepblue will become famous soon enough
Just an FYI so you don't have to wait until dark to do your testing, you can cover up the light sensor at the center-right of the dash and at the base of the windshield. I added a couple of pics to point it out.
Build Date: MDH:052720 [May 27th (Thursday), 8PM -- 2010]
2010 RAM Sport - Deep Water Blue, 3.92 Gears, Flowmaster 40 Series, Volant CAI w/PowerCore, BedRug, BakFlip F1, Bilstein B6 HDs
-cc
Old 11-20-2010, 12:05 PM
Aries's Avatar
Thanks Deepblue. I was wondering what that thing was.
Old 11-20-2010, 02:04 PM
Rep:1845
There are several possibilities as to what's wrong here. The bulbs themselves, TIPMCGW, instrument cluster, headlamp switch, the data bus or power and ground wires to the lights. You can check the J15, M39 and M53 fuses in the TIPMCGW but I doubt this is your problem. I presume the truck is still under the 3/36k warranty, so let the dealer handle the problem.
Old 11-20-2010, 03:17 PM
Aries's Avatar
Thanks for all the replies! I just went out and figured the problem out.
If you push the headlight switch while the headlights are on the foglights will turn off and on. Thanks
Old 11-20-2010, 03:20 PM
Rep:1845
Alrighty then. I figured you knew that since you said didn't work anymore. No problem though, problem solved.
