Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 11-17-2010, 08:33 AM
Rep:1882
Default DS Body Instrument Cluster Removal
REMOVAL
WARNING: On vehicles equipped with airbags, disable the airbag system before attempting any steering wheel, steering column, seat belt tensioner, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in accidental airbag deployment and personal or fatal injury .
<A xmlns="http://www.w3.org/1999/xhtml">
1.Disconnect and isolate the negative battery cable.
2.Remove the fastners (2) that secure the top of the instrument cluster bezel (3) to the instrument panel (1).
3.Using a trim stick C-4755 or equivalent, disengage the retainer clips that secure the instrument cluster bezel (2) to the instrument panel (1) and remove the bezel.
REMOVAL
WARNING: To avoid serious or fatal injury on vehicles equipped with airbags, disable the Supplemental Restraint System (SRS) before attempting any steering wheel, steering column, airbag, seat belt tensioner, impact sensor, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the SRS. Failure to take the proper precautions could result in accidental airbag deployment.
CLUSTER ASSEMBLY
<A name=CHR352832a8cbed1004886ace0da7089134 xmlns="http://www.w3.org/1999/xhtml"><A xmlns="http://www.w3.org/1999/xhtml">
1.Disconnect and isolate the battery negative cable.
2.Remove the cluster bezel from the instrument panel.
3.Remove the two screws (2) that secure the instrument cluster (1) to the instrument panel structural support (3).
4.Pull the instrument cluster rearward far enough to access and disconnect the three instrument panel wire harness connectors (2) from the connector receptacles (1) on the back of the cluster housing.
5.Remove the instrument cluster from the instrument panel.
CLUSTER LENS
<A name=CHR4a4f2d08cbed10048274c0ccb7be1334 xmlns="http://www.w3.org/1999/xhtml"><A xmlns="http://www.w3.org/1999/xhtml">
1.Remove the instrument cluster (1) from the instrument panel.
2.Working around the perimeter of the instrument cluster (3), release the clips that secure the instrument cluster hood and lens unit (2) to the housing and remove the hood and lens.
Old 11-17-2010, 10:06 AM
semichigan's Avatar
semichigan semichigan is offline
Vehicle: 2004
Rep:48
semichigan is on a distinguished road
Send a message via AIM to semichigan
thanks looks pretty straight forward
hope I can add an evic cluster to my st
Old 11-23-2010, 12:19 PM
semichigan's Avatar
Vehicle: 2004
Rep:48
Success I now have the EVIC cluster on my ST ram, the compass doesn't work but thats it. I know have 2 more functional gauges, the bigger EVIC display, and it shows what station the radio is on.
Old 11-23-2010, 12:44 PM
I wonder what it would take to get it to work ?
