Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 11-02-2010, 10:03 PM
ggrif ggrif is offline
ggrif is on a distinguished road
Default Bottom shock bolt!!!!!!!!!!!
I am in the process of trying to change front struts on my 07 4x4 slt bighorn hemi quad cab.
Everything was going great until I tried to remove the bottom shock bolt. The nut came off fairly easily. But the bolt! Wont even move. Tried tapping on it with a small hammer, beating on it with a bigger hammer, even a sledge hammer. And nothing. Bounces in the rubber bushing. Tried a large c clamp to press it out. Might have moved an 1/8 ".
I could get the bolt to turn. And I did try different positions on the shock. Meaning, different levels of support, from a jack stand supporting the outer a arm(shock up tight) to a jack in the middle of the frame(letting the shock fully relax). Thinking it might be in a bind, or have stress on it.
I feel like the bolt has rusted to the metal sleeve inside the rubber bushing and just wont budge.
Hope there is a trick or a tool to "press" the bolt out. I am getting close to letting a repair shop tackle this!
Thanks for any advice.
Old 11-04-2010, 04:43 AM
Rep:1845
You may wind up having to cut off the bolt head. If you do, get a new bolt from the dealer and give it a coat of anti-seize before reassembly.
Old 11-04-2010, 09:45 PM
RAMBOW39 RAMBOW39 is offline
Vehicle: 1999 ram 1500 quad cab sport
Color: green
RAMBOW39 is on a distinguished road
im surprissed there that hard to get out just changed my shocks on my 99 and i just was able to pull them out by hand. If you can get a punch or another bolt about just alittle smaller the the bolt that is in there then try and nock it out. good luck
Old 11-04-2010, 10:01 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Shoot it with penetrating oil and let it soak overnight. Then try rocking it back and forth.
Brian:
Old 11-05-2010, 12:00 AM
You can try some penetrating oil , but if that don't work cut it off and install a new bolt with anti seize as already spoken .
