View Poll Results: What gas companies do you use?
Shell 79 33.76%
Exxon 15 6.41%
Chevron 27 11.54%
Others 113 48.29%
Voters: 234. You may not vote on this poll
Old 10-19-2010, 04:05 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Shell, exclusively.
Old 10-19-2010, 04:16 PM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
I use primarily Chevron.
This topic comes up periodically, either brand, octane, or both. I'll quoteing a message I posted last time that I think is helpful if anyone is interested.
Originally Posted by GPSHSLAX View Post
As for the octane issue, my understanding is that there is no need to run a higher octane than what is needed by your engine/tune etc. The higher octane usually has more addatives to improve the anti-knock (read as anti-preignition) properties. Because of these addatives it is actually likely that there is a slighty (although generally unnoticable) reduction in fuel economy. The advantage is that this gasoline can be used in an engine that is running hotter (as race tuned engines typically do) without the heat causing preignition. The result is that a vehichle that requires 87 usually see's no benifit from 89, or 93, or whatever because they arent opperating at a high enough temp for it to matter. Having said that, if randy says the ECM in the hemi compesates for 89 octane (ostensable increaseing output to take advantage of the higher octane gas?) I would belive it. He is very knowedgable about such things.
The question of brand is a whole different ball of wax and reappears periodically. The truth of the matter is that brand, like octane, almost always boils down to addatives. The gasoline at all your local stations is likely received from the same regional pump station or distributer. Some major cities have more than one, but the principle is the same. In reality the gasoline at all the stations is the same (or at least of unknown quaility). The difference between what you get at each stations is what addatives are added before the tanker rolls out of the distribution center. This is where there are some significant difference. The addative I am talking about here are all essentially detergents. These help prevent engine "sludge", etc., that we have all heard so much about from commercially. While this detergent actually reduced milage as well, it is again my such a negligable amount that it's not worth worrying about. This detergent issue is actually important enough that a group of large auto manucaturers have banded together to publish a list of "Top Tier" gasoline retailers based on the quailty of their detergents. I won't rehash all the requirements but you can read them and get a list of top tier retailers at this link:
http://www.toptiergas.com/
For my money the best addative is Techron (based on reviews I've read) produced by Chevron. Chevron also sells this addative to Texaco and Shell. You will see Techron advertised by Chevron (and now Texaco as they were purchased by Chevron) on their signs and in their commercials, but not by Shell. The reason for this is that Chevron sells the detergent to Shell but does not license them to use the name. This used to be the case with Texaco as well until Chevron purchased them.
The other consideration in terms of station is how well the company will stand behind their product if there is a problem. I got some bad gas at a loves truck stop south of toledo about a month ago that must have had some water in it. The result was that I ended up having to walk back up I-75 to the station at 3:00am and got nothing but the run around from them. I ended up buying two bottles of dry gas and catching a ride back to the truck. I poured the dry gas in and the problem corrected itself immediately. I've heard of other who had similar problem with gas from big name fuel companies, the difference was that they were immediately taken care of. Now I don't usually fill up at this type of station, but at 3am in the middle of northern ohio you don't always get much selection.
This turned into more of a novel than I intended but I hope it helps some folks out.
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 10-19-2010, 09:09 PM
In my area the price of gas can be .15 different within a 4 mile radius . I usually get my gas at Wawa . I use to get it at Citgo , but their out of this world now .
Old 10-19-2010, 09:24 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Costco is my norm. Usually .05 to .10 less than anywhere else. Unfortunately they only have 87 and 93 octane.
Brian:
Old 10-19-2010, 10:23 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
shell bp or mobil whatever cheaper or i just go to nj where is dirt cheap
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 10-19-2010, 10:26 PM
RockyRam's Avatar
RockyRam RockyRam is offline
Vehicle: 2014 Ram
Color: True Blue
Rep:851
RockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to behold
Send a message via AIM to RockyRam
Speedway, unless I'm low and need it quick, then its wherever the heck the closest one is!
Have a Gray Ram?? Join the Mineral Gray Metallic Ramz Group!!!
http://www.ramforumz.com/group.php?groupid=21
Old 10-19-2010, 10:58 PM
FERNMAN FERNMAN is offline
FERNMAN is on a distinguished road
Shell because it makes my truck run like a ninja turtle.
Old 10-19-2010, 11:07 PM
Rep:2616
At home i use BP, if i am on a trip, i use what is handy, usually truck stop gas
Old 10-21-2010, 06:09 AM
M0PARMGNUM's Avatar
M0PARMGNUM M0PARMGNUM is offline
Vehicle: 2000 Dodge Ram RCLB - Auto
Color: Green/silver
Rep:27
M0PARMGNUM is on a distinguished road
Shell and chevron, i find myself mostly going to shell tho because its the most convenient when im out and about around here.
Old 10-22-2010, 11:41 PM
gtfloyd's Avatar
gtfloyd gtfloyd is offline
Vehicle: 2008 Ram 2500 4X4
Color: WHITE
Rep:21
gtfloyd is on a distinguished road
I use Phillips or Quik Trip. I prefer Phillips gasoline and quik trip has amazing soda fountains. lol so when I travel I keep an eye out for em.
What doesn't kill us only makes us stronger, unless we end up comatose. In which case we slowly degenerate into a shell of what we used to be.
