Old 10-01-2010, 02:09 AM
Randy1112 Randy1112 is offline
Vehicle: 99 Ram
Color: Blue
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Randy1112 is on a distinguished road
Default Are they Lights or Darks
Here's a little something to kick around. I recently took my 99 Ram to the local dealership to get a "REAL" headlight alignment and was told that the driver's side was broken so it could'nt be adjusted but they would be happy to order a new one (only $400.00) and change. Reply: ARE YOU NUTS?? After looking around I ordered a PAIR of euro style 1 piece units from a well known suplier. When the new ones arrived I found I had to modify the driver's side turn signal light socket to get it to fit right, (passenger side was a perfect fit). Once installed the light pattern really sucks, (lots of shadows from the facets in the reflector). Does anyone know of a "GOOD" replacement from somebody that actually cares if their product works. Thanks for any help in advance.
Old 10-01-2010, 09:09 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
This might be the excuse (as if you really needed one) to upgrade to HIDs
I'm sure someone on here will be able to give you a better idea of where to get new lights, but a good place to start would be with our supporting vendors.
good luck, and if you haven't already done so, stop by the newbies section to introduce yourself!
Exco
Bill
Old 10-01-2010, 09:11 AM
You could upgrade to HID's as Excoastie suggested.
Or, contact our friends and supporting vendor here, AAC; on projector headlights.
Stop by the Newbie Section, introduce yourself and your truck. Extra credit is given for showing us some pictures of your truck, too!
Old 10-01-2010, 09:19 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Not sure on how the Euros would handle the HIDs, but my projectors are great with them.
Old 10-02-2010, 01:18 PM
tn6478's Avatar
tn6478 tn6478 is offline
Vehicle: 2010 Dodge Ram Sport Quad Cab
Trim Level: Sport Quad Cab
Rep:29
tn6478 is on a distinguished road
HID all the way
Modded so far: 6000k HID low beam and fog, Chrome Step Bar, Tonno Pro Tonneau Cover, LED lights all Around, and Deluxe Mud Splash Guard.
