Old 09-19-2010, 10:30 PM
Xxbrittox's Avatar
Xxbrittox Xxbrittox is offline
Vehicle: 2005 Ram 1500 QC Hemi
Xxbrittox is on a distinguished road
Send a message via AIM to Xxbrittox
Default Driveshaft came off truck..
Soo..Back again with another issue, it seems. My truck is a Dodge Ram 2005 QC 4x4 with a hemi..has 70,000 miles on it.
I searched thru the threads for driveshaft issues but didn't find the exact same problem as mine.
Three days ago..coming home..I noticed a weird grinding noise..kind of like something was rubbing against a tire. I couldn't figure out what it was. The truck sat overnight..and the next day I went to drive up the road.
The noise became louder..almost sounded like an airplane was taking off the rear end of my truck..was real bad. So I pulled over and tried to move the truck to a safer area..well I heard a giant thump like a 100 lb block of steel fell from under my truck and the back tires started skidding and not moving..whole truck shaking..
I got out and the drive shaft had come off of the rear end and was dragging but still attached to the front end. According to my step dad, the fact that the back wheels locked up could be an awful sign.
Does anyone know if I will need a whole new power train or what could have caused this?
Thanks.
Old 09-20-2010, 04:07 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
This does not sound good. At the very least, I am guessing your looking at a new rear end and possibly rear drive shaft. What could have caused this? The list is long, but the first item is the lubricant level in the rear end. I am sure that which ever shop you take it too will fill you in on what they find.
Sorry to say, but his will likely be a costly repair.
brad
Interested in one of my mods?
Old 09-20-2010, 06:57 AM
Juice420's Avatar
Juice420 Juice420 is offline
Vehicle: 2010 RAM 1500 SLT C.C.
Color: Brilliant Black Pearlcoat
Rep:946
Juice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to behold
Thanks.
OMG
Justin
Black Mamba- Flowmaster 40 series, Airaid CAI, 20% tint, GTO taillight covers, ATA nerfs, AVS in-channel ventvisors, Curt hitch receiver, Extang Revolution Tonneau, EZ-down tailgate damper, Recon smoked 3rd brake light, Custom painted engine cover
Black Mamba's Thread
Old 09-20-2010, 08:47 AM
Xxbrittox's Avatar
Yeah..I'm not happy. I'm hoping it's only a u-joint or something similar to that but at this rate, my step father says the whole rear end may need replaced.
Old 09-20-2010, 09:54 AM
The rear end locked up? That's not a good sign...even without the driveshaft removed the differential gears should keep moving freely.
Old 09-20-2010, 10:48 AM
Xxbrittox's Avatar
That's what I thought too Maddog, you think the transmission and everthing else will be okay? Or just rear end needs to be replaced. I should probably call my mechanic to see what they figured out. They may need to ship it out to a dodge dealership.
Old 03-30-2011, 03:01 AM
Xxbrittox's Avatar
I never did update this. The whole pumpkin and rear end needed replaced in my truck because it locked up and basically ate all the bearings. The warranty company, of course, tried to say it was my fault, and I didn't grease the drive shaft and that I was off-roading. I haven't been off-roading in my truck. And the drive shaft clearly doesn't need greased by me. Soo..they ended up paying for a 2,000 dollar repair. One thing after another with my truck.
Old 04-09-2011, 12:47 AM
mbehlok's Avatar
mbehlok mbehlok is offline
Vehicle: 2007 Dodge Ram QC Hemi
Rep:39
mbehlok is on a distinguished road
Holy moly, I guess i should go get my Rear Diff serviced... I put over 900 miles each week.. If this happened on the road, I would be royally screwed..
Luckily for you, Warranty covered it..
K&N CAI, Magnaflow Custom Exhaust, DS Predator CROM 09r11 93 Octane tune W/O MDS, 10" Rockford Fosgate Sub, Kenwood amp
Old 04-09-2011, 01:32 AM
Rep:2616
i only have 41,000 miles on my 2009 Ram & i drive like a grandpa
i just had my u joints replaced on the driveshaft, they were already sloppy & making clunking noises going into reverse
the dealer said that everything was fine now, but, i expect it was a combination of things, maybe the tranny or rear end will be next
time will tell
Old 04-09-2011, 01:58 AM
foolioGrimz foolioGrimz is offline
Vehicle: 1999 dodge ram
Trim Level: 1500
Color: Green
Rep:56
foolioGrimz will become famous soon enough
thats crazy yall have such problems with these new trucks, i drive the Shiznit out of mine, pull down trees, tow more than my max tow weight , take out ford escapes, toyota suv's, fences, trashcans, cactus patches ect.
hope u have better luck
mods-Ranch hand Brush guard, superchip tuner, 75 gal transfer tank, 4.10 gears with detroit locker, 305/70-16 BFG mudders, 2" lift, Chrome Edelbrock carb filter with throttle body mod, and a short glasspack.
