Old 09-11-2010, 10:16 PM
TedP TedP is offline
TedP is on a distinguished road
Default K&N CAI Issue
Hello. I have a K&N CAI intake. It performs well but is very loud, ear piercing, in the cabin at WOT. Has anyone modified a K&N CAI kit to route the filter lower into the fender below the passenger headlight which would result in less cabin noise?
I know Spectre sells some parts I could probably make it happen but want to see if anyone else has had this problem or worked this solution.
Thanks.
Ted
Old 09-11-2010, 10:19 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Getting it closer to the front is a good idea and not just for noise, it also will give it a chance at actually getting cool/cold air vs the hot air in the engine compartment.
Don't take it to low though so that it doesn't get wet.
You could also try building a box to put the filter end in and run a tube toward the front to get that good air.
Brian:
Old 09-11-2010, 11:14 PM
I think you are on the right track. You may just need another tube elbow, another set of clamps, some rubber couplers and one more straight piece of pipe to get it there. Most of that is available at your local parts store or home center store.
Old 09-11-2010, 11:31 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
watch out it you put it near the headlight with wires and what not just encase intake tune gets hot
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 09-12-2010, 10:51 AM
Thanks. Good ideas...time to go shopping now!
Old 09-12-2010, 05:43 PM
Daytona1445's Avatar
Daytona1445 Daytona1445 is offline
Vehicle: 2005 Dodge Ram
Trim Level: Daytona
Color: GoMango
Rep:12
Daytona1445 is on a distinguished road
I put the AFE stage 2 on my truck when I first got it. The filter is behind the headlight. I never heard a single noise from it.
I have the Mopar kit now cause I wanted something with an EO number on it. The only noise I ever heard from it was the TB spacer that came with it so I just removed that.
You could always try a different brand of filter on your intake. it could make a difference.
