Old 08-21-2010, 05:09 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 2014 Ram 1500 Quad
Trim Level: Lone Star
Color: Blue Streak Pearl
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Default Add Cabin Air Filter to 4th Gen for less than $20
I found some info about this mod on another forum, so I did a write up there with pictures. Here is a copy of that write up:
As many of you know, Dodge decided that our 4th Gen RAMS do not need cabin air filtration.
I disagree.
Fortunately enough, it is very easy and rather inexpensive to add this feature to our RAMS.
TOOLS NEEDED:
(1) Sharp boxcutter or X-acto
PARTS NEEDED:
(1) Filter box 'lid'. Dodge part number 68052292AA (About $11)
(1) Cabin Air Filter. Dodge part number 5058693AA, OR, Purolater C25869 ($7), Hastings HAAF1328, or Wix 24578
(These parts are all "OEM" for a 2010 Dodge Avenger, Caliber, Compass, etc. They will not be found by searching in any parts book under 'Dodge Ram'!)
Step 1. Remove lower glove box by gently pulling inward on both sides where the 'ears' are.
Step 2. Locate the filter slot area, which is shaped like a short, fat "T". Using the sharp tool of your choice, cut out the area just inside of the "T". You do not need to cut out the lower 'leg' of the "T", just go straight across. (Refer to pic)
Step 3. Slide in filter with airflow arrow pointing down. The filter, when properly installed, will protrude outside of the slot some. It will not be 'flush'.
Step 4. 'Snap' on the lid. You will need to press on the little 'ears' on each end of the lid (marked with blue tape in pic) until you hear a 'click'. This 'locks' the lid into place.
Step 5. Re-install glove box, and done!
The only "hard' part is trimming out the slot, but the material is pretty thin,,, Just take your time,,,
Future servicing of this filter is super easy!!! Takes about 2 minutes, most of which will be spent emptying the glovebox!
Old 08-21-2010, 05:26 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
That is a superb idea! Kudos to you for coming up with this!
Old 08-21-2010, 05:35 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
WTG on putting this thread up. I had no idea we did not have this in our RAMs. Definitely worth putting one in. Thanks.. Reps for this......
Old 08-21-2010, 05:38 PM
Rep:135
Eh, well, I can't take credit for the mod as I found the info on another forum.
BUT, it is a pretty slick way to add what I feel should be 'standard equipment' on our RAMS!!!
The information I found was posted by a Dodge tech who had a 2010 RAM 2500 'ranch truck' come in with 16k miles on it and a plugged up A/C evaporator. He had to disassemble the whole ventilation system and clean it all up,,,, Big $$$,,,
Anyway, he got to looking at the ductwork, and as they say, "The Rest is History!!!"
I understand the Challengers (or was it Chargers) have a similar mod they can do as Dodge decided they didn't need cabin air filtration either,,,
Rans, I'm 'right there with ya',,, I thought for sure the RAM would have a C A F,,,, (Why not? My 00 Silvy and the wifes 02 Accord had/have one!!!)
When I found out the RAMS don't have a cabin air filter, I researched the subject and came up with a alternative 'fix' from the 'cab fresh filter company'. They actually have a filtration system that attaches to the 'outside' of the RAMs ventilation system intake grills, located on the top of the firewall just under the rear edge of the hood.
They have 2 layers of polyester 'filter' material and a layer of activated charcoal. I ordered the set up direct from cab fresh for about $60. Replacement filter media was about 17 bucks.
I have a pic that kind of shows the cab fresh set up below.
Of course, now that I can have a "OEM' paper filter system, I'll probably won't use the cab fresh system anymore after their filters fill up.
FWIW, Cab fresh DOES make a similar system for the 3rd Gen RAMS. (Thats how I 'found them')
Old 08-21-2010, 06:03 PM
RootBeer RootBeer is offline
Color: RootBeer
Rep:1287
Great how-to. for that.
Brian:
Old 08-21-2010, 06:05 PM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
Great job!!!
Old 08-21-2010, 06:42 PM
Rep:135
Originally Posted by sowardcustoms View Post
Great job!!!
I remember when your research and information with both pics and part numbers made it possible for me to get rid of that %^$#& rattle I had!!!!
Hopefully, this write up might help you out some,,,
Old 08-21-2010, 11:26 PM
Rep:1625
Great job! Very nice
Old 08-27-2010, 12:04 PM
Trim Level: R/T
Color: Gray
Rep:145
There's a guy on ebay selling this as a kit for $99.00...says using mopar parts...
Old 08-27-2010, 12:22 PM
Trim Level: R/T
Color: Gray
Rep:145
It did indeed I ordered the parts thanks...
