Old 08-20-2010, 12:32 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Post CAI Evaluation
I see a lot of posts and questions about CAI's, so I thought I'd do a little checking and do some comparisons. Everything is based on my Ram, 2010 with the Hemi. I'm sure there are other CAI's out there but these are the more common ones.
BFI $329.00 not enclosed and not out in the cold air.
K&N $322.00 partially enclosed and not in the cold air.
Airaid $365.00 partially enclosed and uses some cold air from fender connection, would use full cold air if it was fully enclosed
AFE Stage 1 $336.00 fully enclosed and uses cold air from the fender connection.
Volant $405.00 fully enclosed but has hole in bottom for scoop attachment which would be easy to block. Uses outside air connection on fender.
For my money were I to buy a CAI, I'd go for the fully enclosed CAI's hands down. CAI means "Cold" Air Intake. In my mind any CAI that does not get its air from outside the engine compartment is not a true CAI.
Brian:
Old 08-20-2010, 12:45 AM
ram71351's Avatar
ram71351 ram71351 is offline
Vehicle: 2014 Dodge Ram Laramie
Color: Black Gold Pearl
Rep:45
ram71351 is on a distinguished road
Thanks for the info. RB.
Old 08-20-2010, 01:28 AM
Add AFE Stage 1 to your list and go check it out.
Old 08-20-2010, 01:37 AM
Color: RootBeer
Rep:1287
Thanks, like I said, I'm sure there are others out there. Pretty much the purpose of this thread was to bring them out in the open.
Brian:
Old 08-20-2010, 09:55 AM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 2014 Ram 1500 Quad
Trim Level: Lone Star
Color: Blue Streak Pearl
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Or, you could opt for the 100% enclosed 100% cold air system that already comes with the truck,,, $0.00
Old 08-20-2010, 12:35 PM
Rep:1625
Nice info RB, this should help some folks with their decision
Old 08-20-2010, 01:53 PM
Rep:4072
Good comparison there RB! Guess if it were me, I agree with the Volant for the enclosure, just wish they didn't have to make them so freakin' HUGE, lol! I like the look of it with just the filter, IMO.
Old 08-20-2010, 09:32 PM
I push the skinny pedal
Rep:3277
Some good info there Rootbeer, just to add on the AirAid, it does seal to the underside of the hood
Kurtis
Old 08-21-2010, 08:47 PM
MoparMadness08's Avatar
MoparMadness08 MoparMadness08 is offline
Vehicle: 2008 Dodge Ram
Color: Cool Vanilla
Rep:63
MoparMadness08 will become famous soon enough
as far as the BFI. the air temp is only 6 degrees difference. the air temp while the truck is idling is only 16 degrees difference. if you ever look at a cai that has a heat shield around it its basically for mounting purposes. its really not doing that much.
DSP 91 Oct Tune, BFI Intake, 14" Magnaflow, 180 Stat, Lund Genesis Tonneau cover, Recon LED light bar, Rocky Mtn ATS 305/55/20,
Old 08-21-2010, 08:51 PM
Color: RootBeer
Rep:1287
True about the heat shield, however the brands that are fully enclosed and get their air from outside the engine compartment provide significantly cooler/colder air. This results in increased performance and efficiency.
Brian:
