United Radio
Old 07-21-2010, 12:21 AM
lacamu's Avatar
lacamu lacamu is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: Laramie SLT
lacamu is on a distinguished road
Default interior lights in 98 ram 1500
i was wondering if anyone knew the size of the interior lights on a 98 ram 1500 quad cab im looking to replace them with GREEN led lights so any help would be appreciated
Old 07-21-2010, 12:44 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Like your dome lights and map lights? or your dash lights?
Old 07-21-2010, 12:54 AM
lacamu's Avatar
ya the dome lights and map lights
Old 07-21-2010, 01:13 AM
MS520's Avatar
MS520 MS520 is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi
Rep:109
Here's all the bulbs in your truck.
1998 DODGE Ram Pickup
High & low beam headlamp
9004
9004SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9004ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9004EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9004XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9004CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
3157A
3157NALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
3157A
Rear turn signal
1157
1157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
3157
3157ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
1157
3157
Stop light
1157
3157
High mount stop light
921
921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Fog/Driving light
893
893ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
License plate
1155
1155LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
168
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
1156
1156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
1156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
3157
3157
Front sidemarker
3157A
Rear sidemarker
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Ash tray
161
161LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Glove box
1891
1891LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
579
579LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Step/Courtesy light
194
Trunk/Cargo area
921
Under hood light
561
561LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Instrument-general
158
158LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
PC194
PC74
Check engine indicator
PC74
Hi-beam indicator
PC194
Seat belt indicator
PC74
Brake warning
PC194
Automatic transmission indicator
PC74
Directional signal indicator
PC194
Ignition switch
1445
1445LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Mike
'04 Ram
"Yea its got a hemi!"
Old 07-21-2010, 01:16 AM
lacamu's Avatar
thank you this is really helpful
Old 07-25-2010, 01:41 PM
operatic's Avatar
operatic operatic is offline
operatic is on a distinguished road
Dome light
579
Festoon 42mm / 44mm LED bulb
Old 08-12-2011, 03:43 PM
The Codes's Avatar
The Codes The Codes is offline
Rep:44
The Codes is on a distinguished road
9004
Parking light
3157A
Front turn signal
3157A
Rear turn signal
1157
3157
Tail light
1157
3157
Stop light
1157
3157
921
Fog/Driving light
893
License plate
1155
168
Back up light
1156
3157
3157
Front sidemarker
3157A
Rear sidemarker
194
Ash tray
161
Glove box
1891
Dome light
579
Step/Courtesy light
194
Trunk/Cargo area
921
Under hood light
561
Instrument-general
158
PC194
PC74
PC74
Hi-beam indicator
PC194
Seat belt indicator
PC74
Brake warning
PC194
PC74
PC194
Ignition switch
1445
thanks for the info man! this is gonna save me some searching time for sure!
