Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 06-29-2010, 03:47 PM
DBryant DBryant is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT, Big Horn
Color: Crimson Red
DBryant is on a distinguished road
Default Explain how MDS operates.
I know this has probably been asked before, could not find it with search. How does the MDS system work? Used to be a drag racer in the 60's so I know engines, just don't know how MDS works.
Old 06-29-2010, 04:05 PM
Rep:1625
http://www.ramforumz.com/showthread.php?t=47443
Old 06-29-2010, 04:07 PM
From Remerson228, our resident tech:
The Multiple Displacement System (MDS) provides cylinder deactivation during steady speed, low acceleration and shallow grade climbing conditions to increase fuel economy. Both four and eight cylinder configurations have even firing intervals providesmooth operation. Two cylinders on each bank are active when the engine is in four-cylinder mode – every other cylinder in the firing order. All of the cylinders that are deactivated have unique hydraulic valve lifters that collapse when deactivated to prevent the valves from opening. Engine oil pressure is used to activate and deactivate the valves. It is delivered through special oil passages drilled into the cylinder block. Solenoid valves control the flow. When activated, pressurized oil pushes a latching pin on each valve lifter, which then becomes a “lost motion” link. Its base follows the camshaft, but its top remains stationary, held in place against the pushrod by light spring pressure but unable to move because of the much higher force of the valve spring.
NOTE: It is critical to use the recommended oil viscosity in 5.7L engines that use MDS.
Deactivation occurs during the compression stroke of each cylinder, after air and fuel enter the cylinder. Ignition then occurs, but the combustion products remain trapped in the cylinder under high pressure, because the valves no longer open. No air enters or leaves. During subsequent piston strokes, this high-pressure gas is repeatedly compressed and expanded like an air spring, but fuel is not injected.
Old 06-29-2010, 05:09 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Is there a way to tell if the MDS is working?
Brian:
Old 06-29-2010, 06:10 PM
Rep:1845
The sound of the engine is a big giveaway.
Old 06-29-2010, 06:27 PM
Color: RootBeer
Rep:1287
Sound? What sound? This truck is so quiet the only time I hear it when I put my foot in it.
Brian:
Old 06-29-2010, 07:56 PM
I push the skinny pedal
Rep:3277
I prefer the answer: Magic :LOL
Randy has the real info on it, and like it says there, the viscosity is VERY important, so use the oil type that your cap says or you can run into issues, especially if you live in colder regions.
Kurtis
Old 06-29-2010, 08:32 PM
Rep:1845
My point exactly! When you hear that sound, you can rest assured you are NOT in MDS mode!
Old 07-11-2010, 09:24 PM
RoninHemi's Avatar
RoninHemi RoninHemi is offline
Vehicle: 2010 Ram 1500 4x4 CC
RoninHemi is on a distinguished road
Default MDS on?
I found that if you have an '10, the message center in the dash can be set to let you know when you are in economy mode. There is a sound and some feeling change.
Old 07-11-2010, 09:49 PM
Rep:1845
Eco mode is NOT an indication of MDS engagement.
