Old 05-05-2010, 02:07 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Default 180 Degree Thermostat
Just ordered this i hope it fits. http://estore.websitepros.com/802805...tat/Detail.bok
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 05-05-2010, 02:10 PM
iRESQu iRESQu is offline
Rep:2217
Another piece that I commonly hear is used on the Hemi cars. Let us know what you think! And pics, don't forget the pics...pretty please!
Old 05-05-2010, 04:44 PM
CORUPTWJ's Avatar
CORUPTWJ CORUPTWJ is offline
Trim Level: St
Rep:37
CORUPTWJ is on a distinguished road
I would only suggest this if you are using it on a track only/off road vehicle. Baiscally this will cause your vehicle to run rich because it is not getting up to the correct opperating tempature (computer sees the engine as being too cold). So you are going to see more wear on your engine and lower mpg. I know a lot of people that run cooler temp t-stats in there vehicle, but it is not worth it for me.
Old 05-05-2010, 05:21 PM
09 TRX AGGIE 09 TRX AGGIE is offline
Vehicle: 2013 1500 Black Express 4x4
Rep:130
09 TRX AGGIE will become famous soon enough09 TRX AGGIE will become famous soon enough
keep us posted on the install. i've done those before and it was a pain in the you know what because it didn't fit.
Old 05-06-2010, 10:09 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
I read an article when the Diablo tuner first came out that it was necessary to change the thermostat to a 185 to run the 93 oct tune...not sure why and have asked for opinions but never got any responses....anyone else hear of this?
Old 05-07-2010, 10:34 PM
MotorCityRam's Avatar
MotorCityRam MotorCityRam is offline
Vehicle: 2010 Ram QC 4x2
Color: Inferno Red
Rep:23
MotorCityRam is on a distinguished road
Not necessarily true. Just because you run a 180 stat doesn't mean it's only going to run at 180. And even if it did, a/f will be adjusted for via the o2 sensors. The higher temp stat is for emissions purposes. Once you're to 165 you should be fine.
More importantly...$30?! That's insane for a stat!! It should be easily less than $15 and more likely less than $10!
Sean M
2010 Quad Cap Sport 4x2 / Inferno Red / HEMI / 3.92s / leather / Truxedo Truxsport tonneau
Old 05-08-2010, 10:58 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
are the t-stats the same for gen3 and gen4. reason I ask is the local parts shop only listed the stock 203 degree t-stat and it was $26.
Old 05-08-2010, 11:28 AM
TsubaMaster TsubaMaster is offline
Vehicle: 2002 Dodge Ram 1500
Color: Auburn/ Crimson red
TsubaMaster is on a distinguished road
Actaully when you get down to it all t-stats are the same ( unless its some odd ball vehicle). About running rich and low mpg, that is an incorrect statement. It is race proven the lower the temp the better it performs. Look at the 145 to 165 t-stats that say RACE only. Thats what you might be mistaken with. Now on any vehicle with a computer the lowest you want to go, ( unless you live in a climate that doesn't get below 75 degrees) is 180 degree. If you go below that, in the winter your vehicle will not get to operating temps and will throw codes left anf right. So in conclusion 180 t-stat is perfect, I run one in my 02 ram. Oh yeah 30$ is way to damn much...... Summit racing 14$ bro. Yall have a good one.
Old 05-08-2010, 08:51 PM
I push the skinny pedal
Rep:3277
Lowest I'd go is the 180 for the very reason given above, I live in Alberta and it gets COLD here, even with my 180 installed, I still have a cooler cab than my gf likes in winter. No issues with the engine temps and I'm toasty!
Kurtis
Old 05-11-2010, 05:32 PM
RamTex's Avatar
Color: Stone White
Rep:366
Came in today and put it in, in like 5 mins. Very simple installation only thing that kinda sux is all the antifreeze u gotta buy afterwards. Holds 16 qrts 38 bucks in antifreeze kinda hits yah...i got the premixed stuff btw.
