Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Engine Cleaning
Engine Cleaning Cleaning the Engine bay and under body. Degreasing etc.
Old 04-25-2010, 07:39 PM
SuckmyBigHornEdition's Avatar
SuckmyBigHornEdition SuckmyBigHornEdition is offline
Vehicle: 2006 1500 ram
Trim Level: big horn edition
Color: red
SuckmyBigHornEdition is on a distinguished road
Default Transmission general maintenance
Hey i heard that you should change your transmission fluid every 40,000 miles. i have an 06 ram with an automatic tranny. About 20,000 of those miles were heavy towing. Do i need to change the tranny fluid?
"There is no better form of forced induction than a leaf blower"- MLK
Old 04-25-2010, 07:54 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
I would. You can rarely go wrong with increasing maintenance, especially under heavy use. Not sure exactly what the recommended interval is. How's the fluid look? Dirty or burnt smell, then definitely.
Old 04-25-2010, 08:17 PM
Rep:1877
No, you don't have to yet but I personally recommend 50k for an interval. 100k is whay Chrysler recommends. Discoloration is normal and is not a reason to change it. I do mine every 30k just because I have access to the equipment to do it easily.
Old 11-12-2013, 10:14 PM
dbuzz77's Avatar
dbuzz77 dbuzz77 is offline
Vehicle: 2009 Ram RCSB 4x4
Color: Stone White
Rep:100
dbuzz77 will become famous soon enoughdbuzz77 will become famous soon enough
I changed mine to amsoil (complete flush) at 90,000km (55,000 mi) and the tech showed me there was barely a difference in color between old and new. he said the fords and chevs come in at half the mileage and the fluid comes out black. i noticed a fuel mileage gain after the flush.
2009 RCSB Sport, SC Cortex, K&N air box, all Amsoil fluids, Fan delete, Grounded TB, homemade catch can, homemade gps mount, Fastman TB, EZ down tailgate, Bully hitch step
Then God made a hemi, and knew that it was good.
Old 11-19-2013, 08:27 PM
RED RAM SPORT's Avatar
RED RAM SPORT RED RAM SPORT is offline
Vehicle: 2007 RAM SPORT QUAD CAB
Trim Level: SPORT
Color: FLAME RED
RED RAM SPORT is on a distinguished road
I'd change it, cheap insurance to possibly avoid a major repair. Towing usually halves the service requirement interval. I changed mine at about 35K and am going to do it again at 64K. I go to a transmission shop that drops the pan, and changes the filter. It's probably good for the threads to be exercised. Some shops only flush them and back wash the filter because they are afraid of stripping pan bolts.
Paul J.
2007 Ram 1500 Sport Quad Cab 2WD 5.7
Old 11-19-2013, 08:45 PM
dbuzz77's Avatar
Color: Stone White
Rep:100
they don't back flush any more. they hook up the machine and let the truck pump the new in and the old out. there is a debate because if you take the pan off , you only get 6 out of 15 quarts. if you flush, you don't get a new filter. dodge says change fluid every 60,000 mi so maybe the best is flush at 30 and drop the pan at 60.
Old 06-23-2014, 08:13 PM
sll00's Avatar
sll00 sll00 is offline
Vehicle: 2014 ram sport
Trim Level: sport
Color: GCM
Rep:29
sll00 is on a distinguished road
adding 30k change to my maintenance routine!
My build: http://www.ramforumz.com/showthread.php?t=176640
fluid, general maintenance, oil, question, transmission
