Closed Thread
Old 04-14-2010, 01:56 AM
4doordodge4life 4doordodge4life is offline
Vehicle: 2003 RAM 1500
Color: white (with black parts)
Rep:40
4doordodge4life is on a distinguished road
Send a message via AIM to 4doordodge4life Send a message via MSN to 4doordodge4life Send a message via Yahoo to 4doordodge4life
Default air ram power wire
Im also gonna sell my Air Ram power wire. i do not have a pic as its in my truck right now and its dark out..but here is the stats on it..im willing to take it off my truck to see if it fits on someone else's car but its guaranteed to fit the listed vehical's below. i took that directly form the airram site. im asking $30 shipped
Description:
This easy PLUG & PLAY mod is worth 8-10RWHP in less than 60 seconds. The POWER WIRE will be the quickest and easiest mod you have ever installed. Reports of .5 to 1 MPG have been reported under easy driving conditions.
Details:
The POWER WIRE will fit:
Fits all 2000-UP 3.7L, 4.7L, 5.7L & 5.9L engines and many other Chrysler vehicles.
Works with ANY/ALL stock or aftermarket induction system
May also fit many other 2000 to present Dodge vehicles
*NEW* The =POWER=WIRE=> Now installs on these new vehicles:
2005 Dodge Magnum RT
2006 Dodge Charger 3.5L V6
Add reliable 8-10RWHP to your new Dodge in little as 1-2 minutes of your time!
The =POWER=WIRE=> Is a PLUG & PLAY mod that will give you 8-10HP with less than 1 minute to install. Advancing the timing for increased HP is an old trick that has been used for many years. With the newer computer controlled vehicles there are no distributors to adjust, so to gain additional timing advance we need to alter the signal from the air temperature sensor for the desired advance. Your PCM uses the Air Temperature sensors to help control timing and Air/Fuel ratio.
Your O2 sensors keep your Air Fuel ratio nailed to 14.75:1 at all throttle positions except Wide Open Throttle (WOT) so the POWER WIRE can NOT cause you to run rich during normal driving because no matter what the AFR will be 14.75:1. For this reason The Power Wire has been reported to add 1-2MPG increase when driven lightly. But at WOT the Power Wire will add approximately 2.5% at WOT. When your at WOT you are more concerned with HP than MPG at that moment in time and while passing an additional 8-10RWHP is exactly what your looking for.
The POWER WIRE should not be confused with the "E-bay Mystery Mods" that just claim to give you HP without any explanation as to how that particular mod works... But we try to equip you with the information you need to make the best decision for your performance quest.
When installed the POWER WIRE alters the signal to your PCM making it think the intake air temperature is 20 degrees cooler than the actual temperature at "ALL TIMES". This timing advance is worth approximately 8-10RWHP
The POWER WIRE has been reported to richen the AFR by one full point at WOT, this is good if you have long tube headers and other mods that tend to lean out your AFR at WOT. Installing the POWER WIRE can help cure this lean condition.
On our G-Tech Pro Comp meter it showed a 10HP increase on a 2003 4.7L.
If you need to take it in for service, it takes just 10 seconds to return it back to stock with no evidence of this mod ever being installed!
This is a "PLUG & PLAY" MOD... We have done all the work for you! Gain 8-10HP and 1-2MPG in less than 1 minute, no wires to cut, no tools needed, will not harm your PCM!!! What more could you ask for?
Old 04-14-2010, 02:01 AM
Rep:40
i also have the exhaust from about 3-4" pre-muffler all the way to the tip that ill sell...you will need a 2 1/2" clam and a 2 1/2" to 2 1/2" exhaust coupler thing...which cost all of like 6 bucks...but id sell that exhaust for 40 bucks...you can probably make more then that at a scrap yard for it
Old 04-14-2010, 05:31 AM
oh4ohyeah's Avatar
oh4ohyeah oh4ohyeah is offline
Vehicle: 2004 Dodge Ram 1500 Quad Cab
Rep:88
oh4ohyeah will become famous soon enough
Sounds like the eBay instant power boost mod to me. I'd like to see pics.
Good Hood Fiberglass Functional Ram-Air Hood * Gibson Stainless Headers * Magnaflow Dual Exhaust * Nitto Terra Grapplers * 20% Window Tint
Old 04-14-2010, 12:52 PM
Rep:40
its from nick at airram.com here is the link but ill get a pic of mine.
http://airram.com/product.php?catego...y=power%20wire
Old 04-17-2010, 01:53 PM
Rep:40
bump would like to sell the power wire soon...
Old 04-17-2010, 01:58 PM
Roadrunner Ram's Avatar
Roadrunner Ram Roadrunner Ram is offline
Vehicle: 2011 Dodge Ram
Trim Level: R/T
Color: Mineral Gray
Rep:94
Roadrunner Ram will become famous soon enough
So why are you selling it?
Full LED & HID, F&R Halo's, Debadged, Tinted, Black grille, Grillcraft Mesh insert, K&N CAI, Borla Duals, Nathan P3 Train horn, 70 Roadrunner dust trail graphics. Now I am broke...
Old 04-17-2010, 03:44 PM
Rep:40
trying to buy a sportbike and i need all the money i can get and the power wire it part of the deal..i dont wanna sell it but i will if it will help get me a bike
Old 04-21-2010, 06:08 AM
Rep:40
bump..
and im having (per-exsisting) motor issues and im trying to lessen the power..and taking the power wire off is the only thing i can use to lessen it..cause i need a new motor..BAD
Old 04-24-2010, 10:58 PM
ScatPak07's Avatar
Rep:970
So did this cause your motor to fail??? haha. Ok so you had this thing in? Did it actually work?? Selling this thing for $30 is not going to get you closer to the sport bike haha, there has got to be other issues
I really do not believe I can gain 10RWHP in 1 minute. It seems like those chips that add 50hp and al that bs for $30.
If I do buy something like this and I have a programmer, will it work???
If it works PM me
Old 04-25-2010, 11:58 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
its like a transistor it works sorta not 10hp tho
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Closed Thread
