Old 03-28-2010, 11:59 AM
Brute's Avatar
Brute Brute is offline
Vehicle: 2009 Dodge Ram 1500
Rep:56
Brute will become famous soon enough
Default Installed the Air Lift 1000s!
It was an easy install and they worked out great! I recomend them! The directions were pretty clear and straight forward.
We picked the truck up by the rear end and set the frame on a set of jack stands. Took both back tires off and unbolted the shocks at the bottom. We carefully lowered the rear end watching the brake lines! You can pull those apart if you aren't careful!
The springs came right out with out any major drama. Didn't have to use any spring compressors or fancy tools at all.
We put the passenger side together, air bag, spacer - black plastic puck thing, factory spring isolater, air line - dont forget the little spring hose clamp on the air line or else you have to take it all back apart - Dont ask me how I know.
Pretty much re-assemble it. We ran the air line directly over to the driverside and repeated those steps. Then we cut the air line where we wanted the tee (above the driver side spring bucket) and ran the air line to the rear.
It took us a while to figure out where we wanted the inflation valve. We settled on using an existing hole in the trailer hitch. It is to the driver side of the hitch just above where the safety chain is hooked up.
We put it all back together and took it for a test drive with a good load in it.
I am really happy with them and I would recomend them to anyone who loads their truck up like I do when I go camping or wheeling.
Check them out here:
Old 03-28-2010, 12:04 PM
ScatPak07's Avatar
Rep:970
Cool mod man! Great for people that do heavy lifting with ther trucks!!
Old 03-28-2010, 12:08 PM
Nice video . Looks like they work rather well .
Old 03-28-2010, 12:51 PM
Rep:1625
Nice video, thanks for uploading!
Old 04-24-2013, 09:45 PM
weldguy weldguy is offline
Vehicle: '09 Dodge Ram TRX4
Trim Level: TRX4
Rep:13
weldguy is on a distinguished road
Default Did too much.
No Need to drop axle. I did mine by taking weight off rear and pushed the bags through the spring coils. They return to shape inside the spring. That's how the instructions show it.
Old 04-24-2013, 10:24 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
Ha ha....zzzzzzzzzz...huh....whaa...just woke up from a 3 year nap...
Old 04-24-2013, 10:29 PM
82corvette's Avatar
82corvette 82corvette is offline
Vehicle: 2012 Ram Crew Rambox
Trim Level: Laramie SLT
Rep:128
82corvette will become famous soon enough82corvette will become famous soon enough
Same here as far as installation. Just be sure to check the air pressure now & then, warranty won't cover damage from over or under inflation.
Old 09-30-2013, 01:11 PM
wthawkins wthawkins is offline
Vehicle: 2009 dodge ram
Trim Level: SLT W/tow package
Color: blue
wthawkins is on a distinguished road
I have had my air lifts on for four years and have not any leaks. I keep them at 10lbs under normal (empty load) conditions.
Wally Hawkins
Old 01-28-2014, 09:02 PM
Thumper's Avatar
Thumper Thumper is offline
Vehicle: 2012 Ram 4x4
Color: Flame Red CC
Thumper is on a distinguished road
Anybody know if these bags will work with a 4" drop spring?
K&N CAI - Magnaflow Y - Borla Pro XS - Debadged - Cabin Air Filter - AVS Vent Shades - Pro Maxx Polished Nurf Bars - Rugged Liner Bed Liner - Parachord Interior Wrappings.
Old 01-29-2014, 07:40 PM
mygt8a4re's Avatar
mygt8a4re mygt8a4re is offline
mygt8a4re is on a distinguished road
Get the Durango bags for 3-4" dropped rear, shorter bag.
MYGT8A4RE = My GT Ate A Ferrari, been using that screen name for years....
