Old 01-11-2011, 02:48 PM
I push the skinny pedal
Rep:3277
I've got a couple of animated .gif clips I want to use, but everytime I load one it's just the pic, not the animation. It's allowing me to load, so it's not too big. Any suggestions?
Kurtis
Old 01-12-2011, 12:12 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
check to make sure that you're image size is correct (length and width as well as file size), if that is fine, make sure that the system didn't change the file type form gif to jpeg. Those are the two biggest problems that I've ran in to.
If you still have problems, let me know, I'll see what I can figure out
Exco
Bill
Old 01-12-2011, 12:17 PM
Rep:1625
I've got the same problem as Kurtis, I saved it as a gif to my desktop and resized it, but it still came up as just a picture.
Old 01-12-2011, 12:30 PM
Excoastie's Avatar
Rep:1358
Dillion
I've emailed the avitar. If that doesn't work, let me know and I'll try to post it here
Exco
Bill
Old 01-12-2011, 12:33 PM
Excoastie's Avatar
Rep:1358
I'd give you the same advice City... check the file size, and the dimensions of the images, it can be a bit persnickety when it comes to what it'll allow.
You can click here, to see what dimensions and file size is allowed for your level
Exco
Bill
Old 01-12-2011, 12:36 PM
Rep:1625
Thanks, Exco! I'll keep trying.
Old 01-12-2011, 01:30 PM
Excoastie's Avatar
Rep:1358
Nick:
I think the troubles that you were running in to with resizing the animated image that you found was that the formatting for multiple images tends to get lost when it's resized. That being said, I was able to resize it for you, it's the right size for your avatar, but the file size is too large, so I don't think it'll work here.
Here is what I came up with, using the 4 pics that you sent me. I had to make it a little bit smaller than the 100X100 allowed (it's 86X64) so that I could still use all 4 pics and stay within the 20KB file size limit.
Hope this works for you
Exco
Bill
