Old 03-08-2010, 09:32 PM
Dieselkiss's Avatar
Dieselkiss Dieselkiss is offline
Vehicle: 99 Ram 1500
Trim Level: ST - Very Base Model
Color: Red with grey
Rep:48
Dieselkiss is on a distinguished road
Default Which fuse and relay to use???
I'm installing power windows and power locks in my 99 1500 ST.
I got hold of switch assemblies and switch/motor harness for both from a '95, which is slightly different from the 99 - however my 99 has neither power windows or locks right now, so these are being wired in as new and independent circuits.
I have wiring diagrams for all circuits for both vehicles.
Both circuits are independent of any other circuit on the car (the power locks are being wired in as a 'no key-less entry' and so won't be wired into the TCM - of course both circuits will be wired through the correct fuse/circuit breaker socket in the fuse box).
First.
Power locks.
I'm using the OEM switches and harness, but am using after market solenoids.
The 95 model calls for a 20A fuse and the 99 for a 10A fuse.
As I'm using the 95's switches/harness, I'm thinking I should go with a 20 amp fuse.
Would you agree? or maybe start out with a 10A as it's being installed in a '99, and if it blows a lot, replace it with a 20A?
Electric Windows
I am using the OEM switches, harness and motors for this circuit.
The '95 calls for a 30A Circuit Breaker and the '99 for a 20A CB.
Much the same question; Should I go with the 30A, or start out with the 20A and replace if it blows a lot?
I'm asking this because to me these are independent circuits who's only link to anything else will be the fuse box, so I see no reason not to go with the fuses and Circuit Breakers used in the 95 model - but I wanted to check with those more experienced.
Sorry for the really long post, but I figured I needed to be clear and explain fully.
Old 03-10-2010, 09:37 AM
Rep:1882
Better to start off overprotecting. Go with the 10A fuse and 20A breaker to begin with.
Old 03-10-2010, 12:20 PM
Dieselkiss's Avatar
Rep:48
Yep, I figured much the same. Rather have fuses blowing/tripping than it shorting out and catching fire.
circuit breakers, fuses, install
