Old 03-01-2010, 10:22 PM
aliciahammerich aliciahammerich is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
aliciahammerich is on a distinguished road
Default Power Steering and Braking Problems 2006 Dodge 2500 Mega Cab
I have been having braking and power steering problems on my 2006 Dodge 2500 Mega Cab for about 2 months now. It has been in the shop 4 times with the same problem and nobody can seem to figure it out!
Originally I noticed my PS Pump was humming slightly, a few days later when I applied the brakes it felt as if they weren't working at all then they got really hard to apply, and eventually quickly broke over causing the truck to jerk intensely. Noticed that I had to fill the PS reservoir frequently.
I took it to the first mechanic and they replaced the PS Pump and Hydroboost (for the first time).
For two weeks the truck drove fine, however I noticed it was still leaking PS fluid. The problem came back. I took it back to the same mechanic that repaired it the first time and they expressed that the parts "must have" been bad. The replaced the Hydroboost and PS Pump again. Both parts were NAPA brand.
The truck drove fine for another few weeks although I noticed it was STILL leaking fluid, this time slower and I had to fill the reservoir less frequently.
One day suddenly as I was driving I heard a sound and the steering quickly got tight causing a complete loss in steering and absolutely no brakes. The truck had to be towed, this time to a different mechanic.
This mechanic said the problem was the same, hydroboost and PS Pump. He said the reason it went out was the first mechanic failed to tighten the lines properly causing the pump to blow up. He expressed that I should replace the parts with Dodge brand parts (over 5 times more expensive than the Napa brand parts) and that that would fix the problem.
I got my truck back 3 days ago and $1400 later (bill from this mechanic ALONE) and the problem is STILL there. I've noticed that fluid is leaking, the brakes occasionally "break over" after hard pressure, and there is still a slight humming in the pump.
Has ANYONE had this problem or know what I'm dealing with?? I cannot afford much more work nor time without my truck.
HELP!
Old 03-01-2010, 10:28 PM
Rep:1882
Where is the leak coming from?
Old 03-01-2010, 10:35 PM
I don't know and nobody can seem to figure it out. The first mechanic thought the nut on the top of the steering gear box was leaking, the second said it wasn't. My husband thought it might be leaking through a seal in the gear box.
Also, the second mechanic said that "Power Steering Fluid" should not be used with this system and replaced the fluid with ATF...I have read that this could cause severe damage is this true??
Old 03-01-2010, 10:38 PM
Also, the new PS Pump does not have a dip stick to check the level...UGH!
Old 03-01-2010, 10:51 PM
Rep:1882
None of these so-called mechanics have bothered to add UV dye to the fluid to locate the leak? ATF+4 is the ONLY fluid to be used in the power steering system and yes, power steering fluid can damage the system. At the very least, a complete system flush is needed.
Old 03-01-2010, 11:35 PM
Not that I'm aware of, I am planning on taking it to another mechanic tomorrow. Aside from the fluid leak, what would cause the braking problem to persist (other than the hydroboost and power steering pump)? Both parts are brand new.
The PS pump says directly on the cap "Use Power Steering Fluid Only".
Old 06-22-2013, 12:00 PM
Chasen Chasen is offline
Vehicle: 2006 dodge ram 2500
Trim Level: Slt
Chasen is on a distinguished road
What ever ended up being the problem? I have the same exact issue. Napa pumps and all. I am up to 3 still leaking. I tried to pm you, but it wouldn't let me.
Thanks
Chasen
Old 06-22-2013, 12:22 PM
gmoneyRT's Avatar
gmoneyRT gmoneyRT is offline
Vehicle: 2011 Dodge Ram
Trim Level: RT
Rep:42
gmoneyRT is on a distinguished road
I would recommend as RamTech said a flush with dye...from my experience in the shop I work at we had no luck with napa parts, we stopped buying from them years ago...with parts you get what you pay for in my experience cheaper isn't always better. Hopefully you get this all sorted out and can find yourself a good mechanic too!
brakes, hydro boost, hydroboost, power steering
