Old 02-17-2010, 09:42 PM
sernul sernul is offline
Gender: Not Specified
Vehicle: 2009 Dodge Ram
Color: Graystone Pearl
sernul is on a distinguished road
Question 2009 Dodge Ram ST Crewcab 4.7 ??
What gearing does my truck have? 3.21 or 3.55? and how do you find out?
Old 02-17-2010, 10:36 PM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
Depends on the options it was built with. Give me your VIN number and I'll tell you.
Old 02-18-2010, 01:48 AM
1d3hb13p19j526602
Old 02-18-2010, 09:17 AM
Cormacs's Avatar
Rep:14
I know it's hard to read, but here is the options on your truck. You have a 3.55.
Standard Equipment
Code Description Code Description Code Description
APAS Monotone Paint BABS 160 Amp Alternator BC6S 625 Amp Maintenance Free Battery
BNBS Electronic Stability Program BRTS Anti-Lock 4-Wheel Disc Brakes CGDS Front Height Adjust Shoulder Belts
CGSS Supplemental Side Air Bags CG3S Advanced Multistage Front Air Bags** CKES Floor Covering Carpet
CLES Front Rear Floor Mats CSPS Driver/Passenger Assist Handles CTLS Base Door Trim Panel
CUES Rear Underseat Compartment Storage DMDS 3.55 Rear Axle Ratio DRBS Corporate 9.25 LD Rear Axle
DS8S Conventional Differential Rear Axle GACS Tinted Glass Windows GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror GT6S Power Heated Mirrors, Fold-Away GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning HGBS Dash Liner Insulation HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach JBFS Instrument Panel Black Bezel JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay JPBS Power Locks JP3S Pwr Front Windows, 1-Touch,Up Down
LABS Tire Pressure Monitoring Warning LP LCHS Rear Dome Lamp LMAS Halogen Headlamps
LMGS Automatic Headlamps LPES Cargo and CHIMSL Lamp MBZS Dark Gray Rear Bumper w/Step Pads
MCCS Gray Front Bumper MCLS Gray Upper Fascia MDAS Front License Plate Bracket
MENS Front Wheel Spats MFDS Bright Grille MGAS Ram's Head Badge
MHLS MOPAR Rear Wheel Well Liners MNAS Black Door Handles MS2S Ram 1500 Badge
MWDS Removable Tailgate w/Caliper Latches MXCS Front Bumper Sight Shields NFWS 26 Gallon Fuel Tank
QDAS Light Graystone Pearl Coat RCGS 6 Speakers RESS Media Center 130 CD/MP3 Radio
SBAS Power Rack and Pinion Steering SCFS 4-Spoke Steering Wheel SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers SHAS Front Stabilizer Bar SHFS Rear Stabilizer Bar
SUAS Tilt Steering Column TBBS Full Size Spare Tire TBMS Tire Carrier Winch
TTMS P265/70R17 BSW All Season Tires WEAS 17X7.0 Steel Argent Wheels WF1S 17 Steel Spare Wheel
XA8S Non Adjustable Pedals XBSS Pickup Box XFKS 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring XJJS Locking Tailgate X81S Instrument Panel Parts Module
X82S Door Parts Module X83S Front End Parts Module X88S Tire Wheel Parts Module
YAAS Build To U.S. Mkt. Specifications Z1CS GVW Rating - 6800# 1AAS U.S. Dealer Retail
174S Zone 74-Denver 5AXS Crew Cab 5BAS DS-Vehicle Family
5I2S Two Wheel Drive (2WD)/(4X2) 5I7S Price Class L 5RHS 2009 Vehicle Specifications
5ZGS 5 FT. Cargo Box 5ZLS 1500 Series 594S Vehicle Order Tracking
6USS U.S. Specifications Label 628S Nebraska Ship to State Code 7BBS Carb. Code 02
7CDS Smog Code 04 928S Nebraska Sold to State Code
Optional Equipment
*TX HD Vinyl 40/20/40 Split Bench Seat -V3 Dark Slate/Medium Graystone CBEP 40/20/40 Split Bench Seat
CFMP Rear Folding Seat CJ2P Supp. Side Curtain Frt/Rr Air Bags DGQ 5-Spd Automatic 545RFE Transmission
EVE 4.7L V8 Engine GVBC All Vehicles W/Power Mirrors JP8P Manual Adjust Seats
LE4P Black Exterior Mirrors MPPP Rear Wheel Spats NAS 50 State Emissions
NHDP Heavy Duty Transmission Oil Cooler NHJP Exterior Mirrors w/Heating Element NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller PDA Light Graystone Pearl Coat RAAC All Radio Equipped Vehicles
RDDP Fixed Long Mast Antenna TZAP Goodyear Brand Tires WLYC All Steel Wheels
WMJP Center Hub XBNP Tip Start XKNA Flex Fuel Vehicle
YGVA 4.5 Additional Gallons of Gas ZBSP Spring - Left Rear ZHNP Spring - Left Front
ZNTP Spring - Right Rear ZWNP Spring - Right Front 0ADA FAM: DS TRACKING: 80723T00 MY:2009
0ALA FAM: DS TRACKING: 80828T15 MY:2009 2TAA Customer Preferred Package 2TA 24A Customer Preferred Package 24A
39LA Includes Full Tank of Fuel 42DP St. Louis Assembly Plant North 5A6P Waterbase Paint
Old 02-18-2010, 09:24 AM
Rep:1845
I found it easier to open the page preview in Dealer Connect, save it and then attach it in an e-mail, that way it stays in its original format and is much easier to read.
Old 02-18-2010, 09:29 AM
Cormacs's Avatar
Rep:14
This rapid repsonce is also incomplete on your truck.
ATTENTION:
SERVICE MANAGER
SALES MANAGER
RAPID RESPONSE TRANSMITTAL 09-095
Inspect and if Necessary Replace Inner Door Belt Molding(s)
INVOLVED VEHICLES:
2009 (DS) 1500 Ram Pickup
THIS SERVICE ACTION AFFECTS SOLD AND UNSOLD VEHICLES.
THE VIN LIST AND REPAIR PROCEDURE ARE AVAILABLE ON DEALERCONNECT AND HAVE BEEN INSERTED IN THE SERVICE TAB UNDER RAPID RESPONSE TRANSMITTALS FOR ALL
AFFECTED DEALERS.
THE DEALERS RECEIVING THE VIN LIST AND REPAIR PROCEDURE ARE THE “SHIP-TODEALERS”
AND THE VIN'S LISTED ARE SPECIFIC TO THEIR DEALERSHIP. IT IS THE
“RESPONSIBILITY” OF THE ORIGINAL “SHIP-TO-DEALER” TO NOTIFY THE OTHER DEALER
THAT A RAPID RESPONSE SERVICE ACTION IS TO BE PERFORMED PRIOR TO RETAIL
DELIVERY.
DISCUSSION:
A number of vehicles were shipped with inner door belt moldings that have a thinner material thickness
on the lip and may fold between the door glass and interior trim panel. This may cause the door glass
to bind or squeal when cycled.
PARTS REQUIRED:
AR (1) 55372140AG Weatherstrip, Rear Door Belt Inner (Crew Cab Only)
AR (1) 55112372AG Weatherstrip, Rear Door Belt Inner (Quad Cab Only)
AR (1) 55112373AG Weatherstrip, Front Door Belt Inner (Crew / Quad Cab Only)
AR (1) 55369290AG Weatherstrip, Front Door Belt Inner (Standard Cab Only)
NOTE: ONLY ORDER BELT MOLDINGS FOR VEHICLES THAT REQUIRE THEM BASED ON
INSPECTION.
SPECIAL TOOLS / EQUIPMENT REQUIRED:
1 C-4755 Trim Stick
INSPECTION PROCEDURE:
1. Open all doors of the vehicle and cycle each window up and down separately while watching the
inner belt molding flap of each door. Did the inner flap fold between the glass and door trim panel or
a screeching sound occur from the inner door belt molding when cycling the window down?
a. YES – Proceed with the Repair Procedure.
b. NO – Return the vehicle to dealer inventory or the customer
REPAIR PROCEDURE:
1. Using a trim stick Remove the inner door belt molding. Refer to the detailed removal
procedures available in DealerConnect> TechCONNECT under: Service info> Body>
Door> Molding, Door Belt, Inner> Removal.
2. Install new inner door belt molding. Refer to the detailed installation procedures available
in DealerConnect> TechCONNECT under: Service info> Body> Door> Molding, Door
Belt, Inner> Installation.
3. Return the vehicle to dealer inventory or the customer.
POLICY: Reimbursable within the provisions of the warranty.
NOTE: USE OF THE LABOUR OPERATION INCLUDED WITH THIS SERVICE ACTION ON
VEHICLES OTHER THAN THOSE INVOLVED MAY BE SUBJECT TO CHARGE
BACK.
TIME ALLOWANCE:
LABOUR OPERATION NO:
23-51-17-90 Inspect All Doors Inner Door Belt Molding . . . . . . . . . . . . . . . . . . 0.2 Hrs.
23-51-17-91 Inspect all Doors and Replace One Front Door . . . . . . . . . . . . . 0.3 Hrs.
23-51-17-92 Inspect All Doors and Replace Both Front Door . . . . . . . . . . . . . 4.0 Hrs.
Inner Door Belt Molding.
23-51-17-93 Inspect All Doors and Replace One Rear Door . . . . . . . . . . . . . . 0.2Hrs.
23-51-17-94 Inspect All Doors and Replace Both Rear Door . . . . . . . . . . . . . . 0.3Hrs.
23-51-17-95 Inspect All Doors and Replace All Four Door . . . . . . . . . . . . . . . . 0.6Hrs.
FAILURE CODE: ZZ - Service Action
Old 02-18-2010, 10:06 AM
iRESQu iRESQu is offline
Rep:2217
Gentleman, If you don't mind me chiming in: My husband and I are curious about our transmission with our truck. Where can I do my own research about my vehicle and the vin decoding?
If it makes it easier, *3D7KS28A386181944*
Thanks in advance,
Paris
Old 02-18-2010, 11:11 AM
Cormacs's Avatar
Rep:14
Sorry, no VIN found. Recheck your numbers. We get the information right from chrysler since we are tech's.
Thanks in advance,
Paris
Old 02-18-2010, 11:43 AM
Rep:2217
QUOTE=Cormacs;159110]Sorry, no VIN found. Recheck your numbers. We get the information right from chrysler since we are tech's.[/QUOTE]
Here is the pic of my VIN. Maybe I transposed some digits.
Old 02-18-2010, 06:43 PM
Cormacs's Avatar
Rep:14
A ha. I figures it out. Here is the VIN 3D7KS28A38G181944. Here are the options...
3D7KS28A38G181944
