Old 10-11-2013, 07:29 PM
Dieselguy89 Dieselguy89 is offline
Vehicle: 2001/2005 dodge ram
Color: Red / Blue
Dieselguy89 is on a distinguished road
I just added the hid kit on my 05 2500 and used a single 4700 to fix my flicker issue, soldered it in on the hid kit tail low to negative arrow going to the negative and fixed mine, lamp out is still on but no flicker
Old 10-11-2013, 08:31 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Just get a complete kit from retrosolutions, ballasts and wire harness, the full kit, you will not have any problems, all your doing is setting up a hid kit that is linked direct to the battery, it comes with all the resistors and the capacitors and the relay, and its trigger point is the OEM harness bulb connector. problem solved.
Old 10-23-2014, 09:24 PM
arrowknot arrowknot is offline
Vehicle: 2007 dodge ram
arrowknot is on a distinguished road
Default Here it goes
Originally Posted by txhemi View Post
This is how I fixed mine (I have the Bi-Xenon). Hope this helps!
Here is the right side factory pigtail with the capacitor plugged directly into the empty pigtail. Negative to positive and vice versa.
Here is the left side with the HID harness plugged into the factory pigtail. I had to split the casing of the HID wires to attach the capacitor to them. Again, negative to positive and vice versa.
These are 1000uf 35v electrolytic capacitors from Radio Shack. They cost a whopping $1.62 each and stopping my flickering issues. These capacitors have been in for about 7 months now. Don't mind the mess, I had to peel off the electrical tape for the pics and we all know how messy that can be with some good ol Super 88.
I am about to attempt also mine has 3 wires....07 Ram 1500 so confused I'm just gonna play with it until it works or I electrocute myself, whichever comes first I guess
Old 10-28-2014, 09:05 PM
drvr60 drvr60 is offline
Vehicle: 1996
Color: Emerald Green
drvr60 is on a distinguished road
Default Hid's in my '96
When I installed my led tail lights I just had to use the 6ohm 50 watt resistors. I am pretty confident that is all I will need for HID's to work, but would appreciate someone chiming in if they know something to the contrary when working with an older ram like mine, which doesn't have all the later hitech sensors.- Chris
