Old 02-05-2010, 10:15 PM
angshan's Avatar
angshan angshan is offline
Vehicle: 2004 dodge ram 1500 quadcab
Trim Level: SLE
Color: forrest green two tone
Rep:83
angshan will become famous soon enough
yes just the low beams need the capacitors then. while on high beams your showing a load because of the activation of the bulb moving motor so the truck computer stops the electrical pulsing looking for the load of the halogen bulb. hope that made sense. thats why they work in high beam mode.
Old 02-05-2010, 10:17 PM
ScatPak07's Avatar
Rep:970
Great post! Thanks for the help, this will come in handy for anyone wanting to put some HIDs in there truck.....like me haha
Old 02-05-2010, 10:27 PM
hemijames hemijames is offline
hemijames is on a distinguished road
Smile I noticed you used different capacitors?
Originally Posted by angshan View Post
this is how I hooked mine up. did it for both sides.
Hi there me again, I noticed you used 4700 35v capacitors, is this better than the 1000? will it affect the performance or is it more resistant?
Old 02-05-2010, 10:38 PM
angshan's Avatar
Trim Level: SLE
Rep:83
doesnt effect the output. those are just the ones I used. I believe both will work. I just hope it works on your bulb out in the dash. seems like on some it does and some it doesnt. but it will stop the flicker for sure.
Old 02-06-2010, 01:42 AM
Thanks alot for all your help bro, i really appreciate it! I finally found some good answers, i just hope i dont get the bulb out light...
Old 02-12-2010, 12:27 AM
Unhappy Did the capacitor thing and...
I did the Capacitor thing just as directed, but unfortunately no luck, I still only have the high beams when i turn on the truck. When they are in low beam mode they flicker then shut off, can anyone help me out? Or does anyone know if the canbus or light out detecting system can be shutt off??
Old 02-12-2010, 06:48 AM
angshan's Avatar
Trim Level: SLE
Rep:83
do the arrows on the capacitors face towards the ground wire?
Old 02-12-2010, 10:51 PM
technicallee technicallee is offline
Vehicle: '98 2500 4x4
Color: was white
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
technicallee is on a distinguished road
Unfortunately, you can't shut off either the bus or detecting system. I installed some hid's in a truck today without a problem by using relays and a few diodes. But that's an entirely different solution from this one...
Old 12-24-2010, 10:55 PM
holydiver89 holydiver89 is offline
Vehicle: 2012 Dodge Ram 5.7 HEMI QC
Color: Brilliant Bright White
holydiver89 is on a distinguished road
angshan, did you use 4700UF 35v like in the pic or different numbers? and did it make the lamp out light go away? I ordered some hid canceller capacitors that go between the bulb and ballast but mine still flicker
Old 02-05-2011, 02:24 PM
dcoach222 dcoach222 is offline
Vehicle: 02 ram 4x4
dcoach222 is on a distinguished road
i am having the same problem...9007 hi/lo 9000k that just flashes! so i bought anti-flicker capacitors from stealthauto.com and they still do it! would it help to put caps in where you guys did? where exactly did you install them?
